Vcds ordered
brn7y
Vcds ordered
Post by brn7y » Tue Jul 10, 2012 9:24 am
Is it an Audi aftermarket iPod connector (white connector) not ami.
If so, that was my problem. I removed the connector and plugged the cd back in an everything showed up ok.
Zyox
Re: Vcds ordered
Post by Zyox » Tue Jul 10, 2012 10:01 am
Scatman wrote:Enable the rather subtle alarm blip when you lock the car
How do you this one?
PetrolDave
Re: Vcds ordered
Post by PetrolDave » Tue Jul 10, 2012 5:33 pm
dave635 wrote:Where is the 2nd port ?
There is only one port, the one you've found above the throttle pedal. That has connections to both K-lines (K and K2) and the CAN bus, so if you're using a dual K-line plus CAN lead you should be able to see all the ECUs in your car - unless there's a fault.
pablos007
Re: Vcds ordered
Post by pablos007 » Tue Jul 10, 2012 8:32 pm
Great thread. Very useful info. Cheers :beerchug:
RS3 8V 2016
dave635
Re: Vcds ordered
Post by dave635 » Wed Jul 11, 2012 3:56 pm
Thanks Brn7y, its a white connector & Audi comes up on the Ipod screen when connected. Is this connector removed at the changer or behind the RNSE unit ?
Thanks PetrolDave, also got confirmation from Ilexa that the dual K cable does in fact just have one connector. Looking like the Ipod cable is the culprit.
cheers
2007 RS4 Avant Silver (now sadly sold), 1989 BMW 635csi.
brn7y
Vcds ordered
Post by brn7y » Wed Jul 11, 2012 6:37 pm
dave635 wrote:Thanks Brn7y, its a white connector & Audi comes up on the Ipod screen when connected. Is this connector removed at the changer or behind the RNSE unit ?
cheers
It is changed at the rear of the unit so you need to remove it.
It is the blue plug.
Unplug whole big black plug the small blue is easily removed.
PetrolDave
Re: Vcds ordered
Post by PetrolDave » Wed Jul 11, 2012 6:53 pm
dave635 wrote:Thanks PetrolDave, also got confirmation from Ilexa that the dual K cable does in fact just have one connector.
I've been using VCDS (VAG-COM) for 12 years, so I know I got that right :bigwave:
dave635
Re: Vcds ordered
Post by dave635 » Thu Jul 12, 2012 8:50 am
thanks guys, off to find some RNSE removal tools now ! will report back.
cheers
dave635
Re: Vcds ordered
Post by dave635 » Mon Jul 23, 2012 3:39 pm
update, once i got correct removal tools from Audi & threw away the ebay ones that didn't work....I removed the RNS-E unit & disconnected the Ipod interface. Reconnected the CD changer & now all fine & i can talk to the RNSE. Thanks for the advice. I have changed the startup screen to the RS4 option. Another question on this now pops up, since i have the CD changer online again I thought i'd use it, loaded 6 CDs & hit random play. The system just plays the tracks randomly on 1 CD at a time, in my previous A4 (2002 model) with the same changer (more basic head unit) it played all 6 discs when on random play. Anyone experienced this ?
Users browsing this forum: Google Adsense [Bot] and 111 guests
