Thanks for your input.bilko1 wrote:Drive the car until it is at normal temperature, take home and park up overnight. Next morning open bonnet remove no 3 coil and plug and look in cylinder for water ingress. This will be easier with an endoscope camera. If you see a small amount of water / coolant you have either a cracked head / block or head gasket failure which is small and seals with heat expansion. A friend recemtly came across this on an R8 that the local dealer couldn't diagnose.
I checked for water leak after i had no success installing new coil and injector on cylinder 3. The workshop recorded the water level and set the coolant system under small amount of pressure over and left it over night. They used a tool designed for this. They did also take analysis of the water to see if they found traces of hydrocabon. This is done under the assumtion that if water leaks into the cylinder with no pressure present you will have a leak the oposit way when the engine is running. The test did not identify a reduced fluid level in the reservoir or traces in the water.
Can the teori about water leak still be valid after the results from the two tests above?
If yes, how is that possible?
