cheers for taking a look!Shoppinit wrote:Air flow looks OK.
What a bizarre problem. There must be a wiring problem somewhere. Broken earth wire maybe.
Check the earth connection.
where is the earth connection?
Thats bonkersR1NGA wrote:Very unlikely I know, but mine did something very similar this one day without any warning (at least from what I can tell from the clip). Turned out that the keyfob had lost sync with the ECU and this is what the mgmt did to the idle as a result of being started by an out-of-sync key. Went inside and tried the spare key and Bob's You Uncle - fixed. Had the first key reset at the dealer and it never happened again.
Just a thought...
Afraid its not that. Starting the engine with the spare has the same effect!R1NGA wrote:Very unlikely I know, but mine did something very similar this one day without any warning (at least from what I can tell from the clip). Turned out that the keyfob had lost sync with the ECU and this is what the mgmt did to the idle as a result of being started by an out-of-sync key. Went inside and tried the spare key and Bob's You Uncle - fixed. Had the first key reset at the dealer and it never happened again.
Just a thought...
Shoppinit wrote:You could check the fuse, but I would have thought that if it had blown you wouldn't have any ignition at all. Fuse n° 32.
Freak.Shoppinit wrote:Fuse n° 32.
legendbam_bam wrote:Freak.Shoppinit wrote:Fuse n° 32.
Users browsing this forum: Baidu [Spider] and 48 guests
