Upgrade RNS
Upgrade RNS
Hi does anyone know any company's that will do the upgrade, as it looks a fiddley job and can't be doing with the hassle? Also other than the improved display are there any other significant improvements? Cheers
- 1st Gear
Re: Upgrade RNS
Couldn't name any, but I'm sure there are. Most car stereo places should be able to do the physical swap (probably not the bezel change though), you'll need a garage/stealer/mate with the VAGCOM stuff to make the software changes though.pablotommo wrote:Hi does anyone know any company's that will do the upgrade, as it looks a fiddley job and can't be doing with the hassle?
More files on the SD cards?pablotommo wrote:Also other than the improved display are there any other significant improvements? Cheers
- PetrolDave
Re: Upgrade RNS
Compatibility with CAN AMI so you get a proper iPod/iPhone interface, can use a hard disk, etc.Pyrotechnic wrote:More files on the SD cards?pablotommo wrote:Also other than the improved display are there any other significant improvements? Cheers
Re: Upgrade RNS
I run a car audio installation company in Blackpool. I recently changed mine to a 2012 unit. With some great direction off Dalo and some equally great advise off PetrolDave it's superb. I can do the complete swap for you and reprogramme it. Just PM me if you're near and interested.pablotommo wrote:Hi does anyone know any company's that will do the upgrade, as it looks a fiddley job and can't be doing with the hassle? Also other than the improved display are there any other significant improvements? Cheers
Cheers, Rob.
Users browsing this forum: Google Adsense [Bot], vailpilgrim and 114 guests
