During start up- rough lide/misfire
RS6NOR
Re: During start up- rough lide/misfire
Post by RS6NOR » Wed Jun 20, 2012 4:10 pm
Shoppinit wrote:The MAF values and trim values look normal. No clues there. Probably no vacuum leak.
At least that eliminates some causes.
What are we left with?
More likely causes:
Bad injector(s)
Bad coil pack(s)
Unlikely causes:
Bad/Fake plugs
Bad fuel - has your car been off the road for a while?
N80 / Active carbon filter - might be worth testing.
ECU defect
You can test the injectors. I wonder if it's worth pulling the injectors and sending them for cleaning / testing?
I think I would be tempted to swap the coil packs out.
Hi,
thanks for your reply.
Ref. your comment on the coils. As i have mention before have i changed, coil and injector on cylinder 3 where you have the error code. I have double checked that it was done on the correct cylinder 3 they did the work on and they where doing it right.
Could there be other coils which are failing than the one providing cylinder 3 and still get error messages on cyliner 3?
Why is the rough idle going away after 30 second after cold start up if the coil pack are weakend/failing. would not you expect the rough idle to more frequently present also when the engine is warm?
RS6NOR
Post by RS6NOR » Wed Jun 20, 2012 4:15 pm
Ryan_Pestell wrote:I still think coil or coil's and the missfire has killed the lambda's (Also quite common)
i agree that the lambda is most likely killed by the misfire.
Post by Shoppinit » Wed Jun 20, 2012 4:24 pm
Maybe inside the coil pack there is a broken join that expands and makes contact when it starts to warm up.
RS6NOR
Post by RS6NOR » Wed Jun 20, 2012 4:40 pm
Shoppinit wrote:Maybe inside the coil pack there is a broken join that expands and makes contact when it starts to warm up.
Find it hard to believe. I would image that the temperature over the coils do not increase so fast? I also think that if this was the case the rough idle would last longer in cold weather since it would take longer to reach " connection temperature" for the joint. This is not the case, rough idle last equalliy long in cold and warm weather...
Post by Shoppinit » Wed Jun 20, 2012 4:47 pm
Fair enough. Good luck.
RS6NOR
Post by RS6NOR » Thu Jun 21, 2012 1:08 pm
A bit in the dark about what should be my next step in the hunt for my rough idle cure... My list of next steps (which i have limited faith in) are as follow:
1 Tempted to start by changing out all the coils for a complete set of new ones...
2 then change all the injector with new ones...
3 then change the ECU with a new one...
If not any of that helps i am completely lost... :)
Comments?
Ryan_Pestell
Post by Ryan_Pestell » Thu Jun 21, 2012 1:35 pm
Where abouts are you in the country?
Daytona RS6+ Sold :(
Now Building a 500HP Lotus Exige
grizz
Post by grizz » Thu Jun 21, 2012 7:20 pm
Is the car using water ?
I've had a few with head gasket failure that misfire on start up .
Unit 20
0151 3366888
PhilT
RS246.com
Post by PhilT » Thu Jun 21, 2012 10:55 pm
grizz wrote:Is the car using water ?
+1. Mine didn't use water though.
RS6NOR
Post by RS6NOR » Sun Jun 24, 2012 8:52 pm
Ryan_Pestell wrote:Where abouts are you in the country?
I am located in Norway.
RS6NOR
Post by RS6NOR » Sun Jun 24, 2012 8:57 pm
I have not noticed that the car uses water. If leaking fluid i guess there should have been alarm related to low level in expansion reservoir?
I suspected this quite early and there was done a leak test on the cooling water system. They where not able to find a leak.
Can it be that the leak is small ( droplets) such that the accumulated volume is to small to notice?
RS6NOR
Post by RS6NOR » Sun Jun 24, 2012 9:01 pm
Which procedure will you suggest when verifying if the top gasket is fried or not?
bilko1
Post by bilko1 » Sun Jun 24, 2012 11:56 pm
Drive the car until it is at normal temperature, take home and park up overnight. Next morning open bonnet remove no 3 coil and plug and look in cylinder for water ingress. This will be easier with an endoscope camera. If you see a small amount of water / coolant you have either a cracked head / block or head gasket failure which is small and seals with heat expansion. A friend recemtly came across this on an R8 that the local dealer couldn't diagnose.
Post by Shoppinit » Mon Jun 25, 2012 7:16 am
Rule 44: Grizz will only post once in any thread and never reply to further technical questions on that thread.
OK, it's not an official rule, but I think we should make it one.
mavada
Post by mavada » Mon Jun 25, 2012 7:53 am
:thumbs:
he will post twice max if he smells there could be a future customer...but thats all because hes busy... :wink:
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Users browsing this forum: srichards and 248 guests
