Hi,Shoppinit wrote:The MAF values and trim values look normal. No clues there. Probably no vacuum leak.
At least that eliminates some causes.
What are we left with?
More likely causes:
Bad injector(s)
Bad coil pack(s)
Unlikely causes:
Bad/Fake plugs
Bad fuel - has your car been off the road for a while?
N80 / Active carbon filter - might be worth testing.
ECU defect
You can test the injectors. I wonder if it's worth pulling the injectors and sending them for cleaning / testing?
I think I would be tempted to swap the coil packs out.
thanks for your reply.
Ref. your comment on the coils. As i have mention before have i changed, coil and injector on cylinder 3 where you have the error code. I have double checked that it was done on the correct cylinder 3 they did the work on and they where doing it right.
Could there be other coils which are failing than the one providing cylinder 3 and still get error messages on cyliner 3?
Why is the rough idle going away after 30 second after cold start up if the coil pack are weakend/failing. would not you expect the rough idle to more frequently present also when the engine is warm?
