Front armrest....
- 1st Gear
Re: Front armrest....
Mine's mostly because I've driven an Impreza for the last few years which has a hill-hold clutch, hence having completely forgotten how to do hill starts (tried one the other day in the RS and stalled it (and then messed up the restart, then nailed it away from the lights ASAP))
I use my armrest all the time. Took a few weeks to get used to gear changes with "the claw", but now feels totally natural.
Shove the phone in there and some sunny's... sorted.
Yes, easy to retrofit.
You can order the Armrest kit, which comes with all parts including the retainer mount and a top covering, however you will also need to order a matching leather top for your car as the kit comes with a cloth top.
I think it's about £250ish for all parts, and the fitting is easy, however you need to cut a whole near the ashtray. I would recommending keeping an eye out on eBay as you should be able to get one for £100 with the correct top.
I have an armrest and am about to retrofit, however I need the template which comes with the kit so that I can position it correctly - any one have one of these?
£250 not too bad. I used to get a lot of parts for my M3 from FAB Breakers, is there an equivalent for Audi?TimDogg wrote:This might go on for a while vestax- If I remember rightly it can be done but I don't think it was cheap - £250 springs to mind - you might need to call Audi on this one.
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
66 Sapphire BMW F80 M3.
18 Mythos Black RS4
14 Daytona Grey RS6
08 Monza Silver RS6 Avant
07 Phantom Black RS4 Avant
Loads of BM's inc. 4 x M's
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
Is that £250 ish including the matching leather top or is it £250 ish then £900 or something ridiculous for the leather top?!!!
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
- PetrolDave
Either you only drive on exceptionally flat roads or you have a lot of friction in your wheel bearings, etc. - in neutral or with the clutch out my RS4 will roll easily on any road that isn't absolutely flat.Dom81 wrote:hence not needing either brakes or handbrake to keep the car stationary
Here's the advice that ADIs are told to give on handbrake usage:
"Use the handbrake if on a hill or a pause turns into a wait
always used mine (hate my r8 not having one) never had any probs but maybee short people find it more awkward being further forwardPetrolDave wrote:Either you only drive on exceptionally flat roads or you have a lot of friction in your wheel bearings, etc. - in neutral or with the clutch out my RS4 will roll easily on any road that isn't absolutely flat.Dom81 wrote:hence not needing either brakes or handbrake to keep the car stationary
"Use the handbrake if on a hill or a pause turns into a wait"
Or wanting to burn away from the lights in a cloud of dust and engine scream.PetrolDave wrote:Either you only drive on exceptionally flat roads or you have a lot of friction in your wheel bearings, etc. - in neutral or with the clutch out my RS4 will roll easily on any road that isn't absolutely flat.Dom81 wrote:hence not needing either brakes or handbrake to keep the car stationary
(well was in my advacned test anyway
Gutted that mine hasnt got an armrest, never got in the way when I had the S3 and S4. I might retrofit at some point, but at £250 abit excessive i think at the minute....!!
Rab
Armrest can get in the way and not that useful for resting arm on for short people like me. Handbrake can be used if not tilted all the way down. HOWEVER, I SEARCHED OUT A CAR WITH ARMREST COS IT MAKES THE INTERIOR LOOK MUCH BETTER WHEN IT'S DOWN!!! Sad as it may seem, whenever I park up and leave the car, I put Armrest down for visual delight when I walk back in to car.....and for any passer bys who want to admire interior
B7 RS4 saloon Sprint blue facelifted. BMC AIR FILTER, 8mm REAR SPACERS, H &R lowering springs, NON RES VALVED MILTEK...(current)
Subaru Impreza P1 modded..330bhp (4yrs)
Merc 190e 2.5 16v cosworth..black with full black heated leather recaros ..200bhp (5yrs)
Cavalier 2.0 Sri 130bhp (5yrs)
Front armrest....
I must be the only one who uses it, is it bad to admit i had it down when and when using it doing hot laps of the ring? A man must relax
- 1st Gear
Tru dat! Right hand on the wheel, right elbow on the door handle/switch-pack ledge, left hand on the gearknob, left elbow on the armrest. How else are you meant to drive?! Only time it changes is for adventurous cornering when both hands go on the wheel.sonny wrote:A man must relax
LOLsonny wrote:I must be the only one who uses it, is it bad to admit i had it down when and when using it doing hot laps of the ring? A man must relax
As you said, Tamworth Audi have confirmed that the front armrest is only available as a spare with black cloth top. That doesn't help me much with a silver grey leather interior and they are not aware of a leather top. Is this available from Audi to match any interior?wms wrote:Yes, easy to retrofit.
http://elsaweb.spaghetticoder.org/doc/A ... 34817046/3wms wrote:....
Dashed line at dimension B is intended as a guide.
A 9 mm
B 5
C 39
D 31
E 15
F 16
G 9
H 43
opening is 64 mm long
Users browsing this forum: MapleSyrupJizz and 107 guests
