Shift Paddles Found Them
Re: Shift Paddles Found Them
Post by chunky79 » Fri Jun 15, 2012 6:51 am
Shoppinit wrote:Footlong, if you can get me an OE paddle I will see if I can model it up in CAD and get some quotes to get some made from my guys.
I might be able to get an oem paddel to you in a weeks time if your still wanting one. Should have had my spare steering wheel trimmed by then so can strip the one thats on the car
Post by Shoppinit » Fri Jun 15, 2012 8:41 am
Cool. I'll give it a shot, why not.
Mr Footlong
Post by Mr Footlong » Fri Jun 15, 2012 8:59 am
Ferfick. I went hunting quickly yesterday but was fast reaching the opinion that the only real way to do it was going to be to cannibalize a steering wheel. Went off looking for one but put about 30 seconds effort in to it to be perfectly honest. I would that to keep it as straighforward as possible you will need to send both paddles as although chances are that the left will be a symmetrical mirror of the right one intenally and externally, you won't know until you remove both anyway. Look at the machining below if you don;t follow what I am waffling on about:
Without a much higher res picture there, it almost looks to me like these can be physically popped in/out of place but I am not currently willing to try that theory unless I get bored.
Current:
Gone:
Post by Shoppinit » Fri Jun 15, 2012 9:09 am
Yes, that was my understanding of the system, also. There was a US company selling one that looked exactly like your photo (might even be that one) but who doesn't make them any more. Definitely need the clip on ones. Can't be gluing stuff.
rob8457
Post by rob8457 » Fri Jun 15, 2012 9:38 am
These are better images Footlong
Bobby
RS6 Saloon 04- Non Res Milltek- Forge dump valves- Led Rear Lights- Ally steering paddles- 20" Rotors- RNS-E- I.G Air Fiters,
Post by Shoppinit » Fri Jun 15, 2012 9:45 am
Those are going to be a biatch to machine...
Do they have to be in aluminium? What about injection moulding?
Mr Footlong
Post by Mr Footlong » Fri Jun 15, 2012 9:59 am
Thanks Rob, I don't see those popping off like I thought. Looks like a pin/rod goes through the middle, unless it is something that just grabs either side of the hole.
Current:
Gone:
Post by chunky79 » Fri Jun 15, 2012 10:36 am
Gents, hadn't even crossed my mind that my father in law is a pattern maker. Got some sweet talking to do I think. :lol:
rob8457
Post by rob8457 » Fri Jun 15, 2012 12:35 pm
Its just one screw to undo then just make sure the spring stays where it is when removing it, it really is that easy to remove, when i took the plastic paddles to a engineering company they said also it would be hard to reproduce them cheaply they quoted over £400 just for the tooling, but i was always under the impression that there was a machine out there and you just pop the part in that you wanted to reproduce and hey presto in came out as a exact copy, or am i talking crap here, i am sure i have seen a video of it working somewhere
Bobby
Post by Shoppinit » Fri Jun 15, 2012 3:05 pm
Yeah, I could get them SLS easily enough, but they would be plastic. If there was a demand, and plastic was OK, then I could get an injection mould made up.
Upon reflection, I think anodised aluminium will give the best finish. I think a decent CNC mill will be able to produce the parts easily enough.
Keaney
Post by Keaney » Fri Jun 15, 2012 11:15 pm
I'd be happy with injection moulding.
Could one
Possibility be to provide extenders which clip onto the existing ones?
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
Post by chunky79 » Sat Jun 16, 2012 3:56 pm
Gents. These are for sale on rs6.com. Is it worth trying to get these made over here? Will there be enough interest to make it worth while?
Post by Shoppinit » Sat Jun 16, 2012 4:24 pm
If they're for sale on RS6.com why not buy them there?
Post by chunky79 » Sat Jun 16, 2012 4:31 pm
Er, that's kind of my statement. I thought you lot used that site?
Post by Shoppinit » Sat Jun 16, 2012 4:34 pm
Not me. Can't stand the banter.
