Massive boost leak
Massive boost leak
Had a cousin pop over and he wanted a spin in the car, took him out and it was running flawlessly, going like <beep> off a shovel, then I thought I heard a weird noise, turned the music down and it got louder and louder. It sounds like someone letting air out of a tyre but 100x louder, I couldn't hear my exhuast it has become that loud. It only does it when it hits 3,000 RPM. There is no real noticeable performance reduction. Anyone had this? I've made two videos to try and demonstrate the noise but it is hard to capture. It sounds as it if it is coming from the drivers side, intercooler hose popped off?
http://www.youtube.com/watch?v=SLkKpTKZ ... ata_player
http://www.youtube.com/watch?v=0vXFrRU_ ... ata_player
Re: Massive boost leak
Hope its nothing serious.
be a hose somewhere deffo jubilee clip come loose on intercooler bumper off jobby
get Vagcom on it for fault code?
KV53 YML - RS6 Avant - Stolen Hampshire
RS 51X CS - RS6 Avant - Sold
Massive boost leak
Has happened in my previous rs6; it was the pipe connecting the turbo to i think intercooler? It had come loose...
Lost my Vag Com.
Car is having the intercoolers done at Unit 20 in a few days anyway, so could leave it until then, or I could get it to MRC before then if Doug can book me in, don't fancy driving up to U20 when the car isn't right and I bet the AA wouldn't recover unless it physically broken down.
I had mine do this, a bottom intercooler pipe had popped off, need a new rubber pipe as it had "shrunk" think it was about 70 pounds :-/
Had it repaired outside my house, maybe a AA man could put a new one on If you get the part from Audi? I had my old one put back on. It it kept popping off, so put a new one on! maybe AA could temp repair before you trip away?
Hi Amar,
I had the same thing happen to me with the passenger side hose to the intercooler. Take the engine undercover off, remove the bottom intercooler hoses-clean all the oil away and then replace and tighten till get the new wagner or venair silicone boost hoses and hose clips. Oil from the charge mixture gradually weakens the grip of the oem rubber hoses so they slip off.
Also check that source of external oil on hoses, if there, not coming from leaking rocker cover gaskets.
john
john
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
Similar thing to mine, bottom hose popped off, I replaced them with wagners hoses.
Still got my old ones though Amar if you want me to post you some spares?
You could get some Mikalor clamps too, they are much stronger than jubilee clips
Daytona RS6 Avant
It happens to everyone at some point; Consider it losing your intercooler virginity. You've already fooled around and got to base 2 with the holes in them, now you've popped your cherry.
Easy fix. Get the car in the air, sump shield off, and you'll see the intercooler hose that's come off. Put it back on and tighten that jubilee clip as much as you dare. And then some.
I like the look of those Mikalor clamps.
- posterboyj
JCS Hi Grip hose clamps; I highly rate.
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
Yoda?
Could be time for the wagers.
Daytona RS6 Avant, PSS9, Milltek system with 100 cell, Wagners & hoses, MRC map / 533 ps & 865 nm. Phaeton Ducts. Daily drivers / VW T5 and R1.
Sorry to hear your problems, Amar.
As it happened all of a sudden, 90% chance it will be the popped off bottom hose, as others mentioned. If you can get your car on the ramp, it shoud be no problem to get it sorted.
Good luck with repair and please, keep us updated!
current: Quartz Grey A6 C6 Avant 3.0 TDI Le Mans
prev:Daytona grey RS6 C5 Avant,Black BMW 320D Coupe (E92),Red Honda Accord 1.8
Users browsing this forum: Google [Bot] and 52 guests
