S4 Auto's
AndyT_uk
S4 Auto's
Post by AndyT_uk » Sat Jun 09, 2012 4:43 pm
Hi all,
I'm starting to look for another S4 now after a brief stint back in an ST220. I've previously had a b6 S4 and really regret selling it!
The last one was a manual but there are quite a few auto's about and wondered if anyone could share some knowledge about them? Are they all tiptronic or mulitronic boxes? Are they known to be reliable in the B6/7 and is there anything to be wary of when taking a test drive? Any certain type of mileage that they're known to become problematic?
Also, has anyone made the change? I've not really driven an auto for a great deal of change so am wondering what it'd be like and whether its really worth considering them.
Cheers!
Andy
Re: S4 Auto's
Post by HYFR » Sat Jun 09, 2012 5:01 pm
they are all tip
i would avoid em ... really takes away from the driving experience and they do not rev to the red line so the car makes less power and they are heavier, and worse MPG !!
cobraBLACK
Re: S4 Auto's
Post by cobraBLACK » Sat Jun 09, 2012 9:39 pm
D_K wrote:they are all tip
Correction: they get better MPG at higher speeds because they rev lower in the equivalent of 6th gear.
I've never heard of any common problems.
Audi S4 Avant (B6, 2004) in Goodwood Green.
Re: S4 Auto's
Post by HYFR » Sat Jun 09, 2012 9:48 pm
thats hardly a correction is it
cobraBLACK
Re: S4 Auto's
Post by cobraBLACK » Sat Jun 09, 2012 10:37 pm
D_K wrote:thats hardly a correction is it
The difference is significant; best most manuals can get is mid-twenties but the auto will see around 30.
gottanS
Re: S4 Auto's
Post by gottanS » Sun Jun 10, 2012 2:09 pm
I would rather take the hit on the mpg and enjoy the V8 with a manual box, auto boxes have their place but depends on your driving style.
Jocky
Re: S4 Auto's
Post by Jocky » Mon Jun 11, 2012 1:22 pm
To get back to the OP's original question, I own a Tiptronic B6 S4 and think it's great, I never liked autos before and would have agreed that manuals are better etc.etc. But after owning mine for nearly two years now there is no way I would take a manual, auto boxes now are better than you could really wish for. Okay the change could be a little quicker when using the paddles and it would be better if it didn't overide you sometimes (i.e. change up when you get near the rev. limiter) but you have 3 different options of how to drive the car depending on how you feel and as previously mentioned get better MPG.
My recommendation would be to drive examples of both, but definitely try the auto in S mode as it makes the throttle more sensitive and holds on to the gears for longer. Only if you intend on using the car on track would I recomend taking the manual, but then I would suggest you look at another car.
Mine has been bullett proof so far, as has the whole car, although I would recommend changing the box oil as mine came out like treacle at 58k.
RoyalMile
Re: S4 Auto's
Post by RoyalMile » Thu Jun 14, 2012 9:05 pm
Hi
I tried both manual and auto and decided on the auto because:
1. It has a higher final drive which makes the car quieter at speed - around 30 mph/1000 revs in 6th
2. I do a lot of long journeys and I get 25 - 27mpg on a typical run cruising at 85mph
3. The slush box makes the car surprisingly happy and docile in heavy traffic
4. The auto is easier to drive smoothly, especially in traffic
5. The paddle shifts are great for overtaking on A roads
6. Shift speed and smoothness is good, way better than I expected coming from a B6 3.0 q tip
My S4 is my daily drive, I don't own another car so getting the balance right is important, the S4 slush works well for me.
goose
Re: S4 Auto's
Post by goose » Fri Jun 15, 2012 10:10 am
"My S4 is my daily drive, I don't own another car so getting the balance right is important, the S4 slush works well for me".
Quite frankly, that's the most important thing.. whatever works well for you :beerchug:
Enjoy it!
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Users browsing this forum: No registered users and 15 guests
