Leaking Seat Valves
adsgreen
Re: Leaking Seat Valves
Post by adsgreen » Sun May 27, 2012 9:58 am
Looks pretty basic - I'm guessing the leak is from the black circular rubber grommets?
nij
Post by nij » Mon May 28, 2012 11:06 am
adsgreen wrote:Looks pretty basic - I'm guessing the leak is from the black circular rubber grommets?
Not sure, the rubber grommets seems a good fit.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
adsgreen
Post by adsgreen » Mon May 28, 2012 11:53 am
Hmm - looking at it I can't see anywhere else that would wear quite so bad.
My guess is that the solenoids pop in/out when activated and expose the hole to vent the air. The seal would have to be pretty damn tight for it to hold the pressure.
There's a thread I found for the S6 where the later solenoids had a much beefed up rubber seal - almost three times the size!
nij
Post by nij » Mon May 28, 2012 2:02 pm
ads, if you're interested, I can send you one of the old valve.
Timster
Post by Timster » Mon May 28, 2012 3:48 pm
I suspect the orange, rubber/polyurethane washer is the most likely culprit.
Over time these will "dent" as per your photo and with age will start to seep/weep air.
Specter
Post by Specter » Sat Oct 04, 2014 1:10 pm
I had the same issues with my seat and was able to repair it using a spare part from eBay.
The part was originally from an Opel Recaro seat but it did work out well, because the part of the solenoid which was defect was only the top of the housing, which holds the three connectors. It had a hair thin crack in it, almost unnoticable. I tried to repair it with some glue first, but that was not satisfactory.
Anyway, I just thought I might share this, in case someone else wants to go this route.
Users browsing this forum: No registered users and 407 guests
