Brake pad warning light
MalcolmSu
Post by MalcolmSu » Sat May 12, 2012 2:50 pm
i changed my front pads last weekend. At the time it seemed a straight forward job and everything has been fine through my daily commutes this week. Until last night after I got home I started the car up again and as I put the car into Drive the brake pad warning light on the dash came on.
I've just taken a the wheels off and everything looks fine. The wires and connectors for the wear indicators all look okay.
Any thoughts on what could be wrong? Anything I can test? If I just disconnect them will the warning light on the dash go away?? :-)
cfcdoc
Re: Brake pad warning light
Post by cfcdoc » Sat May 12, 2012 5:47 pm
Dont mean to tell anyone how to suck eggs but I`m assuming it was an amber light and stayed on and wasnt the alarm going off as you changed into drive without having your foot on the brake fully?
She may be big and heavy but its whats on the inside that counts.....
MalcolmSu
Post by MalcolmSu » Sat May 12, 2012 6:00 pm
no unfortunately it's on permanently
Post by Shoppinit » Sun May 13, 2012 9:51 am
Are you sure it's pads and not just the general brake warning symbol? Checked the fluid level?
MalcolmSu
Post by MalcolmSu » Sun May 13, 2012 10:58 am
Fluid level is fine. It's the orange circle with two 'pads' to the left and right of the circle.
cfcdoc
Post by cfcdoc » Sun May 13, 2012 11:06 am
MalcolmSu wrote:Fluid level is fine. It's the orange circle with two 'pads' to the left and right of the circle.
I was getting that mate a while back, turns out the pad sensor was dirty or had moved or a bit of both, cleaned, returned and light hasnt come back.
Post by Shoppinit » Sun May 13, 2012 11:08 am
OK, if it's orange then it's the pads. Odd. You can disconnect the sensors, but it's a bit odd why they would make a circuit.
Place to start is disconnecting them from the pads and seeing if the problem goes away. If not then the problem is further upstream.
MalcolmSu
Post by MalcolmSu » Mon May 14, 2012 7:42 pm
yesterday was a washout for us so I never got a chance to look at the sensors again... Then when I started the car up this morning to drive to work the DIS warning had gone! Drove to work and then 32 miles later as I pulled into the car park, I braked and it came back on again. Still there on my drive home tonight... :(
Phill R
Post by Phill R » Mon May 14, 2012 10:29 pm
Had a similar thing last year. On mine, it turned out to be the loom that goes from the front hub to the inner wing which had a broken wire internally. Used to put the pad warning lamp on intermittently. Discovered it by wiggling the wires until the light came on.
swannny
Post by swannny » Mon May 14, 2012 10:31 pm
i'm pretty sure the brake in the warning wire is quite common on audis, my mates s6 used to break, and so did his s4!
Chorlton
Post by Chorlton » Mon May 14, 2012 10:47 pm
You can program it out via Vag Com.
I hate all these sensors & poop for the very reason you have to post.
Take it back to old skool where the 1st you know the brakes were goosed was metal on metal, lol
Program out the tyre pressure & paking sensors while your at it as there poop too :audibash:
MalcolmSu
Post by MalcolmSu » Mon May 14, 2012 11:15 pm
Chorlton wrote:You can program it out via vag com.
This is the fourth set of front pads I've fitted but the very FIRST time I've managed to do it without having to replace the disks at the same time! Not that the sensors did me any good the previous three times anyway. :D
MalcolmSu
Post by MalcolmSu » Mon May 14, 2012 11:19 pm
do you have Vagcom? Are you local to me? :)
Chorlton
Post by Chorlton » Tue May 15, 2012 2:47 pm
I'm in Falkirk too!
Good friend owns a garage in Bo'ness & fixed all mine.
Not an official Vagcom one but works on mine & other vag's for almost everything.
www.linkstyrecentre.co.uk
Ask for Graham & quote chris with the RS6 so he knows what your on about :bash:
Rupert
Post by Rupert » Tue May 15, 2012 5:56 pm
Give the connectors a wiggle on each side, you should be able to do this with the wheel still on as far as I can remember (as it happened to me too after a pad change).
It was just a dodgy connection at the connector in my case.
Users browsing this forum: Shoppinit, srichards and 79 guests
