New Carbon Clean system on Whealer Dealers
Rigsby1208
Post by Rigsby1208 » Thu May 03, 2012 10:49 am
Hi
I was watching the current series of Whealer Dealers last night...where the buy, fix up and sell on cars. This one they bought a Jag XK and did a carbon clean, via a machine which connected via the fuel rail. The machine used two different solutions one for cleaning pre combustion - manifold, injectors and the other cleaned post combustion. It went through an hours program with the car running on these two fluids - fuel pump on car deactivated. They said it is a brand new method for doing carbon cleans.
Made a massive difference to the emissions etc on a before and after test.
I was wondering if anyone had heard/seen this before? if it might be a cheaper/quicker solution to our carbon build up issues???
Mr V10
Re: New Carbon Clean system on Whealer Dealers
Post by Mr V10 » Thu May 03, 2012 11:26 am
I'm just about to watch that episode now, will try and catch the name of the machine.
barryrs
Post by barryrs » Thu May 03, 2012 11:32 am
This looks like the equipment - Terraclean engine de-carbonizing treatment
http://www.youtube.com/watch?v=5VCuki_-vXQ
Post by bam_bam » Thu May 03, 2012 11:50 am
Rigsby1208 wrote:Hi
*Wheeler
The gains were a massive 9HP and 7ft/lbs!
I don't think this will help the B7, it's direct injection and the carbon'd areas aren't wetted by the modified fuel. I could be horribly wrong...
stu
Post by stu » Mon May 07, 2012 3:16 pm
Bumping this as one of the new members was asking about it in the new members area. What bam_bam says sounds right to me, but I know feck all really.
Anyone tried it?
Is it more useful and the DIP3/air intake stuff in the FAQs?
Mr V10
Post by Mr V10 » Mon May 07, 2012 10:02 pm
That sucker mechanic that does all the free labour for Mike said a carbon clean on a V8 is about £60-70 iirc.
P_G
Post by P_G » Mon May 07, 2012 10:18 pm
That would be a N/A non FSi V8, I'm not sure it is designed for FSI engines
sakimano
Post by sakimano » Tue May 08, 2012 6:48 pm
bam_bam wrote: I don't think this will help the B7, it's direct injection and the carbon'd areas aren't wetted by the modified fuel. I could be horribly wrong...
having not seen the video, I'd say this is bang on. Although again, I don't know what the process is in the video. If they are hooking into 'the fuel rails' on an MPI car, then it's a non-starter. Won't help the Rs4's most common carbon problem (valves etc which are not touched by fuel per bambam)
Unless it unleashes magic scrubbing fairies, that survive the atomization process in FSI and then go back towards the intake valves etc and do their work. Then it might be worth considering.
Post by bam_bam » Tue May 08, 2012 8:29 pm
sakimano wrote:Unless it unleashes magic scrubbing fairies, that survive the atomization process in FSI and then go back towards the intake valves etc and do their work. Then it might be worth considering.
Don't rule it out, it is an Ameri-CAN invention after all. So with their strength of marketing hype, any/everything is possible. Besides, I'd buy something that promises enslaved scrubbing fairies clean your engine, wouldn't you?
Users browsing this forum: Google [Bot] and 98 guests
