Here are my graphs, it did 473 in April 2010 stock, then 481 last week stock and I think the 486 is with the downpipes and then 535 with the map. I'm not 100%, hopefully Doug will come across this and make it clearer.
might need alot of luck.rossi46 wrote:Agreed - I want the best balance between the car running as best as possible, whilst wanting to remain legal etc. Will be interesting to hear how you tomorrow - Good luck
Amar wrote:Then you want to gut your pre cats and get a stage two remap, about £1300 iirc, add another £900-1,000 to that if you haven't already got a Milltek.
Dunno, I reckon if you're confident enough to take this on in the first place then you're doing okchunky79 wrote:
Odd. JVCiggen made a lot more power by removing the precats and that on a standard map. I wonder where the difference comes from.Amar wrote:I think the 486 is with the downpipes and then 535 with the map.
Haha. Good one. Rule 16.Amar wrote: I'm not 100%, hopefully Doug will come across this and make it clearer.
I did have Wagner IC's as well, which heat up slower than stockers so the power curve stays "on course" a bit longer in dyno conditions. Well it's a theory anyway.Shoppinit wrote: Odd. JVCiggen made a lot more power by removing the precats and that on a standard map. I wonder where the difference comes from.
The actual ramps are stupidly wide. I did my van's cambelt on there the other day and told my gaffer it would have been better doing it lying on the floor.Shoppinit wrote:Can't you use the ramp to raise the body on blocks?
Thats one of the only job's that me and my mate have failed atMr Footlong wrote:Well you gave it a damn good go and at least saved yourself a load of cash gutting them yourself
I'm going down on the 4th mate , i could wait by Lem for you and race downAmar wrote:Are you getting a Milltek at the same time too? Daveperc tells me you really need one to take advantage of the gutted cats, I need to go back to MRC for final alignment of parts. What date you booked in? Could try and coincide, then you can hear what a catless RS6 sounds like, trust me, it's the bomb.
Catless resonated is perfect, no drone and VERY loud when you floor it, and a real woolfing V8 noise on the overun if that makes sense, can't find a word to desribe it, Mooch says its a popping and banging but mine is really refined.
Guessing i will be down there early as it's a 10k service, brake fluid (ate purchased todayAmar wrote:4th will work with me, what time? You can take it for a spin if you want, 844 NM is laugh out loud fast. I'll try and book in the same day.
Users browsing this forum: Google Adsense [Bot] and 73 guests
