Looking for some advise...
klauster
Post by klauster » Wed Apr 04, 2012 2:46 pm
My car is in with Audi at present, I have a couple of fault codes which they have cleared, but they are saying the car might need a new oil breather valve? Costing near enough £500? Anyone heard of this or had to have one fitted/replaced.
They are saying when they take the oil filler cap off while the car is running they can feel quite abit of suction... like there is a vacuum leak, although saying that they have checked for leaks and can't find anything...
Car runs fine, other than the occasionally slightly higher revs when coming to stationery....
klauster
Re: Looking for some advise...
Post by klauster » Thu Apr 05, 2012 11:01 am
I can only imagine the number of views but lack of response is due to no one else having this issue...
P_G
Post by P_G » Thu Apr 05, 2012 11:03 am
I may be having the same issue which is why it is burning oil at 1200 miles per litre but won't know for sure until the week after next when it is being looked at and only then will knwo the cost. Will let you know then mate. :beerchug:
adsgreen
Post by adsgreen » Thu Apr 05, 2012 12:30 pm
I've been thinking... Do they mean the pcv oil separator?
I didn't think the rs4 had a conventional oil breather but could be wrong.
What are the codes?
Not sure I've got the wrong end of the stick but I thought the crankcase was beg pressure do taking the filler cap off would have suction...
klauster
Post by klauster » Fri Apr 06, 2012 8:38 am
Well I have my car back and all I can say is OMG, what a difference :)))) car idles perfectly now, kick is more than ever and power is better than when I got the car 4 years ago, I have the parts that were replaced over the last couple of visits so will pop some pics up :)
Really really happy, got good will on the repair as well :) £200 was a bargain considering what it's done to the car
P_G
Post by P_G » Fri Apr 06, 2012 10:04 am
Would be interested to know what they replaced Nick and part costs as I may also replace certain parts given the number of miles and age my car is.
RSKiwi
Post by RSKiwi » Fri Apr 06, 2012 11:44 am
+1 always good to learn a bit more about what can wrong and how to fix it!
____________________
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Pug 405 NZ Touring Car
Toyota Landcruiser
klauster
Post by klauster » Fri Apr 06, 2012 12:47 pm
Here are some quick pics of the parts I had replaced
Solenoid for Airbox flap
And this was described as an Oil Breather Valve by Audi York
A seal has broken on this bit:
This is the spring loaded valve which works via the vacuum (mine was no longer spring loaded)
Part no.
P_G
Post by P_G » Fri Apr 06, 2012 1:37 pm
Did you get a breakdown on parts costs on your invoice?
klauster
Post by klauster » Fri Apr 06, 2012 2:07 pm
Not had the invoice yet, being sent in the post, think the part is 200 then 2 to 3 hours labour
adsgreen
Post by adsgreen » Fri Apr 06, 2012 3:55 pm
Just wish Audi put in some one way valves - slightest hiccup and it cripples the car
adsgreen
Post by adsgreen » Fri Apr 06, 2012 3:59 pm
That part no googles as an oil seperator valve - wonder if it's the valve that allows the oil collects by the triple filter to be released back into the sump.
P_G
Post by P_G » Fri Apr 06, 2012 6:42 pm
I wonder whether a faulty one could affect consumption of oil. If it is stopping release back into the sump from the separators and they are full then blow by won't be collected and more burnt which will work its way thorugh the cylinders and exhaust?
kay
Post by kay » Sat Apr 07, 2012 11:21 pm
I wonder if we all need to follow this treatment path if our cars are doing the raised rev thing. I recently replaced my vacuum solenoid for manifold to the improved version to see if it helps my sticking manifold flaps; although the tech said the problem stil exists, my epc light hasn't come back on yet, but boy do I notice my car running a lot smoother, so that new solenoid has done something. Might be worthwhile changing the airbox solenoid too as a matter of precaution.
B7 RS4 saloon Sprint blue facelifted. BMC AIR FILTER, 8mm REAR SPACERS, H &R lowering springs, NON RES VALVED MILTEK...(current)
Subaru Impreza P1 modded..330bhp (4yrs)
Merc 190e 2.5 16v cosworth..black with full black heated leather recaros ..200bhp (5yrs)
Cavalier 2.0 Sri 130bhp (5yrs)
P_G
Post by P_G » Mon Jun 04, 2012 9:42 am
Holy thread resurrection Batman! Kay, do you have the part number for the bit you replaced? I'm in the process of sourcing all vacuum solenoid parts and replacing them inlcuding the oil separator, air box, engine mount and manifold even though my car doen't necessarily use the manifold or airbox one anymore. If the system is intact by replacing all then hopefully it will have stronger vacuum readings.
Users browsing this forum: Google [Bot], Squadr0n_ and 131 guests
