Kick gone at 5.5k revs
Re: Kick gone at 5.5k revs
Post by bam_bam » Wed Mar 28, 2012 5:04 pm
ArthurPE wrote:how was the vol eff calculated?
can you set up an excel spreadsheet
col 1 rpm
col 2 calculated mass air flow from rpm, displacement and an air density using temp, humid, atm P ~ the same as the following vagcom run
col 3 actual vagcom measure mass air flow
col 4 = col 3 / col 4 in %
I have this at home, want to compare
edit: just did it using saki's data from this post, now to figure out how to post it
Timster
Post by Timster » Wed Mar 28, 2012 5:07 pm
ha ha, yeah.
(working-out what's for tonight's dinner)
ArthurPE
Post by ArthurPE » Wed Mar 28, 2012 6:56 pm
graduation photo
:biggrin3:
on a serious note
is the throttle open 100% <5000 rpm in 4th gear?
if so Saki, can you run some 4th gear 2.5 to 5.5k runs in 4th (to compare torque with and without the throttle limited) without the forum having to come up with bail ;)
it be interesting to see some 3-8k runs with the intake flaps opened at various rpm's
stock ~5.5k
try it at 2k
4k
etc.
just to see what it does to the torque output
klauster
Post by klauster » Thu Mar 29, 2012 9:15 pm
Car still isnt right :(
Very strange, when in neutral, foot off accelerator and still moving, its revs 1200rpm then settles down once I stop.....
adsgreen
Post by adsgreen » Thu Mar 29, 2012 10:29 pm
Not uncommon - I've had cars do this.
It can be related to emissions as the moving rules are different.
Not sure if the RS does it but mine isn't standard mapping.
stu
Post by stu » Thu Mar 29, 2012 10:46 pm
klauster wrote:Car still isnt right :(
Mine's standard. I'll have a go at replicating that tomorrow.
klauster
Post by klauster » Fri Mar 30, 2012 1:07 pm
Anyone know if it could be clutch switch related?
adsgreen
Post by adsgreen » Fri Mar 30, 2012 1:11 pm
No reason why not - cheap easy fix so worth trying
stu
Post by stu » Fri Mar 30, 2012 9:42 pm
Played around today. I can get the 1200rpm rise if...
- I'm rolling in very slow moving traffic in too high a gear, such that the engine rpm is being pushed towards the stall point
- and then I use the clutch to disengage the gear completely.
The engine comes up to 1200, stays there for a few seconds, then drops back down to the usual idle rpm.
That's probably of no use whatsoever but hey.
ArthurPE
Post by ArthurPE » Sat Mar 31, 2012 2:15 am
klauster wrote:Anyone know if it could be clutch switch related?
does your cruise control work?
RS6chris!
Post by RS6chris! » Sat Mar 31, 2012 8:05 am
Mine used to do EXACTLY the same as this too.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
klauster
Post by klauster » Sat Mar 31, 2012 9:33 pm
I will try it tonight
kay
Post by kay » Sat Mar 31, 2012 11:40 pm
This "clutch depressed/neutral gear and consequent raised revs that settle down after a few seconds" thing has been happening to my car of late and I'm pretty sure it never used to do that.
I've never used the cruise control, but Wil try that to see if it works or not.
B7 RS4 saloon Sprint blue facelifted. BMC AIR FILTER, 8mm REAR SPACERS, H &R lowering springs, NON RES VALVED MILTEK...(current)
Subaru Impreza P1 modded..330bhp (4yrs)
Merc 190e 2.5 16v cosworth..black with full black heated leather recaros ..200bhp (5yrs)
Cavalier 2.0 Sri 130bhp (5yrs)
Terry1948
Post by Terry1948 » Sun Apr 01, 2012 4:57 pm
I think they all do it something to do with ecu.
klauster
Post by klauster » Sat Apr 07, 2012 9:40 am
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 190 guests
