FOR SALE RS6+ (34/999)
AdamM
Re: FOR SALE RS6+ 34/999
Post by AdamM » Thu Mar 08, 2012 1:00 pm
Are the turbo's not under a lot of stress though ? surely they will go bang at some point ??
RS 6 C5 - one day
Flickr Photo page
http://www.flickr.com/photos/44883793@N05/
Mr V10
Post by Mr V10 » Thu Mar 08, 2012 1:02 pm
It has uprated Turbos by Loba they go upto 650 BHP, not standard ones.
sweegie
Post by sweegie » Thu Mar 08, 2012 1:15 pm
Getting high torque outputs from the turbos puts different stresses on them than top end bhp - max torque will be in the mid rpm zone where the turbos can flow well at huge pressure ratios, for relatively little spin rates. This high pressure ratio that puts a lot of load on the turbos thrust bearing, which can indeed go bang.
It's likely that the Loba turbos on Amandas car have very good thrust bearings, hence running the high pressures in the midrance & high torque figures :thumbs:
Recycling dinosaurs for fun
Post by chunky79 » Thu Mar 08, 2012 2:04 pm
she also has different cam's
Post by bam_bam » Thu Mar 08, 2012 2:19 pm
sweegie wrote:It's likely that the Loba turbos on Amandas car have very good thrust bearings, hence running the high pressures in the midrance & high torque figures :thumbs:
Indeed it probably does, being Loba's no doubt. However, I'm going to go out on a very green, shaky and narrow bamboo shoot limb to say this: "What happens when a car with a slipping slushbox is dyno'd?"
Post by Shoppinit » Thu Mar 08, 2012 2:29 pm
Depends on why it's slipping. If it's slipping because the clutch drums are screwed then not all the power is being transferred from one gear to the other. If it's slipping because your TC is toast then it depends on what's wrong with the TC. If it's the lock-up clutch then it shouldn't make any difference because your TC won't lock under WOT anyway, which is what you'd be dynoing at.
Post by bam_bam » Thu Mar 08, 2012 2:49 pm
So the dyno sheet should have a lower or higher torque number? I know logic should state that it would be lower due to slippage, but dyno's can be confused/confusing in how they measure torque.
Post by Shoppinit » Thu Mar 08, 2012 3:09 pm
Could be either depending on what is slipping. The torque multiplication phenomenon that is induced by the TC only adds to the confusion. I believe this is why so many RS6 display such high torque numbers. Until the impellor and stator are almost at the same speed, there will be some kind of torque multiplication going on. Slushboxes are black magic, I tell thee.
Post by bam_bam » Thu Mar 08, 2012 3:12 pm
Shoppinit wrote:Until the impellor and stator are almost at the same speed, there will be some kind of torque multiplication going on. Slushboxes are black magic, I tell thee.
'zactly wot I is tinkin mon.
*I have not idea why I turned Jamaican*
Malcolmx92
Post by Malcolmx92 » Wed Apr 04, 2012 6:47 am
After taking a deposit last week for a sale price of £16,500 and giving the buyer 3 days to clear balance.
He has been a no show!! Despite numerous attempts to contact him.Therfore car is now reduced to £16,500...
cfcdoc
Post by cfcdoc » Wed Apr 04, 2012 7:57 am
Shoppinit wrote:Maybe the avants are more expensive to insure because they are so much better? ;)
Indeed and Direct Line arent stupid either, they tripled it when they heard I bought a mugello..fastest colour and they knew it...bobbing rastards.. :bigwave:
She may be big and heavy but its whats on the inside that counts.....
Malcolmx92
Post by Malcolmx92 » Wed Apr 04, 2012 1:18 pm
Rolling on the floor laughing :biggrin3:
cfcdoc
Post by cfcdoc » Wed Apr 04, 2012 2:16 pm
you aren't interested in a swap by any chance for a non plus mugello :bigwave:
Malcolmx92
Post by Malcolmx92 » Thu Apr 05, 2012 10:35 pm
Would love to swap for another Mugello but would have to be a C6...but not in the current climate....
Thanks any way cfcdoc :thumbs:
Malcolmx92
Post by Malcolmx92 » Fri May 18, 2012 2:57 pm
Now fitted with new Alternator from local Audi dealer...
Users browsing this forum: Google [Bot] and 266 guests
