Hope these are some help to you young man
Sorry for the crap quality, must sort out settings on my phone
Hmm, is the glovebox one even switched then or is it just on all the time when the sides are do you know?Shoppinit wrote:Glove box light is retarded. The side lights have to be on for it to light up when you open the glovebox door.
Ringo, update to this. As I said earlier, they do dim in/out with locking unlocking but aren't as bright as the old school bulbs in there.Was out last night so played with the reading lights and found that when the headlights etc are on, a lower voltage must be applied to the circuit for the reading lights as when turning them on without the main interior lights, they are dim and flicker, as if being fed borderline initialization voltage. However, when headlights etc aren't on they run at normal voltage regardless of nightlights when the main interior lights are on.el_ringo wrote:How do the reading lights compare? Similar brightness?
Just to check do they dim up and down too?
Users browsing this forum: Bing [Bot] and 228 guests
