cam belt kits
tonyredmond
cam belt kits
Post by tonyredmond » Sat Mar 03, 2012 1:04 pm
hi has anyone used these for cambelt kits www.blauparts.com ,or should you
just use main dealer for these, is it worth changing themostat aswell as waterpump,
and alternater, where do you stop? mines due now at 58000 miles
Mr V10
Re: cam belt kits
Post by Mr V10 » Sat Mar 03, 2012 1:11 pm
Buy genuine Audi from TPS. You want to do the cambelt,watrerpump,thermostat and all the associated rollers/dampers too. Whilst your at it, it is a good chance to replace/repair your intercoolers if they are leaking.
Mr Footlong
Re: cam belt kits
Post by Mr Footlong » Sat Mar 03, 2012 1:38 pm
Tony, DIY job or going somewhere for it?
Current:
Gone:
neastev
Re: cam belt kits
Post by neastev » Sat Mar 03, 2012 2:53 pm
I did some surfing on the blauparts kits and there was alot of negative comments from the US forums...
Landed up buying an SKF kit with an OE belt, water pump and t stat. Fitted it myself and thought the SKF kit was first class
tonyredmond
Re: cam belt kits
Post by tonyredmond » Sat Mar 03, 2012 3:04 pm
still unsure who to use, how do you repair the coolers?
Re: cam belt kits
Post by chunky79 » Sat Mar 03, 2012 3:18 pm
Jd weld. You need a pack for each end of the cooler.
Re: cam belt kits
Post by Shoppinit » Sat Mar 03, 2012 4:21 pm
I like SKF for bearings and timing belts. I've worked there and they are a high quality manufacturer.
grizz
Re: cam belt kits
Post by grizz » Sat Mar 03, 2012 4:42 pm
We're able so supply and post out a full genuine kit if required.
Unit 20
0151 3366888
tonyredmond
Re: cam belt kits
Post by tonyredmond » Sun Mar 04, 2012 9:40 am
thanks Grizz, shame your so far away, do you supply the Jd weld for the coolers that chunky
recommends
Mr Footlong
Re: cam belt kits
Post by Mr Footlong » Sun Mar 04, 2012 9:57 am
You have QST in your sort of area, as well as 4 rings in Dartford (Mobile!) and AMD Essex if memory serves:
http://www.qstuning.com/
http://www.4rings.co.uk/
http://www.amdessex.com/
All these guys have been mentioned on these forums so feel free to go have a hunt :)
Current:
Gone:
swannny
Re: cam belt kits
Post by swannny » Sun Mar 04, 2012 10:46 am
thats the answer there for you grizz, you need a depot in east anglia, it'd be a little goldmine!
grizz
Re: cam belt kits
Post by grizz » Sun Mar 04, 2012 11:04 am
Yes we can ,
I've got one in from norwich ....
Unit 20
0151 3366888
swannny
Re: cam belt kits
Post by swannny » Sun Mar 04, 2012 3:01 pm
i got all excited then Grizz, i thought you were going to open a branch in Norwich!
good job i read it twice!
Users browsing this forum: Majestic-12 [Bot] and 312 guests
