Pics of mine - aka the blank canvas!
Mr Footlong
Re: Pics of mine - aka the blank canvas!
Post by Mr Footlong » Fri Mar 02, 2012 6:31 pm
Maybe it's just me then but mine are around that but only around 1cm of thread mating per bolt seems a little scary when you factor in the weight and how sideways I like to go wherever possible ;). Still haven't got around to checking it yet but will try tomorrow as will only take 2 secs.
Current:
Gone:
Post by Shoppinit » Sat Mar 03, 2012 12:09 pm
If there are 6 turns then that's about 10mm. If that's what it is, that's what it is. I'm not going to second guess Audi - I presume they have anorak engineers to do finite element analysis on that kind of thing.
Mr Footlong
Post by Mr Footlong » Sat Mar 03, 2012 12:13 pm
Looking at the pic I tokk I am near as damnit on 6-7 turns so will leave it at that. What torque are you putting on yours? I am doing about 110ftlbs (not 110+quarter turn etc) which seems too little feel-wise when bolting them up but I am always one for doing things up MAN-TIGHT :D
Current:
Gone:
Post by Shoppinit » Sat Mar 03, 2012 12:22 pm
Did you mean Nm? They should be torqued to 120Nm, but I do them to 130 because 120 doesn't 'feel' enough.
Mr Footlong
Post by Mr Footlong » Sat Mar 03, 2012 1:37 pm
Shoppinit wrote:Did you mean Nm? They should be torqued to 120Nm, but I do them to 130 because 120 doesn't 'feel' enough.
Nope, ftlbs. I was hearing that people tightened them to 140NM (MRC on this car for instance when they were fitted) but that felt too little to me. The only torque wench I have capable of going to 140NM, reads in ftlbs. 103 ftlbs is about 140NM I believe. I am doing 110 as I don't feel safer at anything lower than that. Hell, I would have them on a lot tighter if it was me but I am working roughly to what others were using.
Current:
Gone:
Post by Shoppinit » Sat Mar 03, 2012 4:35 pm
Mr Footlong wrote:but I am always one for doing things up MAN-TIGHT :D
Broken too many bolts that way. Starts to cost a lot of money. Last thing I broke by overtightening because it didn't feel enough was the camshaft on my golf. Doh!
Post by chunky79 » Sat Mar 03, 2012 4:39 pm
I've never used a torque wrench on my wheel nuts. I just use me and my knuckle bar
swannny
Post by swannny » Sat Mar 03, 2012 5:43 pm
me too, i've never owned a torque wrench, and like footlong says, man-tight!
Post by Shoppinit » Sat Mar 03, 2012 5:45 pm
All depends on how much of a man you are, I suppose. ;) I need the torque wrench to avoid twisting the bolts into spirals. :assflash:
Post by chunky79 » Sat Mar 03, 2012 5:49 pm
Shoppinit wrote:All depends on how much of a man you are, I suppose. ;) I need the torque wrench to avoid twisting the bolts into spirals. :assflash:
I own a torque wrench but I can control my hugeness of power. I am very talented :thumb:
swannny
Post by swannny » Sat Mar 03, 2012 6:52 pm
well i'm not overly strong, but if i put the whole 15stone on it, its tight! :biggrin3:
Mr Footlong
Post by Mr Footlong » Sun Mar 04, 2012 10:02 am
I am looking forward to seeing if Shopp is 6'7" like me but just so happens to be built like a brick sh!thouse or is a tall & gangly fella ;). Had my fair share of sheared bolts in the past from going MAN-TIGHT, luckily never on a wheel. :)
Current:
Gone:
Post by bam_bam » Sun Mar 04, 2012 10:17 am
I have. I'd hate to know how much torque I put on the conical bolts for my wheels. When releasing they have a tendancy to crack into first movement. I think it's time I get a torque wrench.
Post by Shoppinit » Mon Mar 05, 2012 10:44 am
So as not to poo on the TV thread, how about one of these:
http://www.dabonwheels.co.uk/CK-O_DAB2011.html
and one of these (might work ok with the diversity system):
http://www.dabonwheels.co.uk/Kinetic_DA ... itter.html
Mr Footlong
Post by Mr Footlong » Mon Mar 05, 2012 10:57 am
Confused, I linked you to thAT DAB unit in some thread a while back but thanks ;) I have looked at that splitter before and am keeping it in mind but I would want absolute max signal strenght so vee shall see. Can't make my mind up fully yet over upgrading to outdated but factory RNS-E or getting a far better double DIN nav unit at the expense of it not looking nearly as good. Not a massive priority currently.
Current:
Gone:
Users browsing this forum: Bing [Bot], norwichphoto and 29 guests
