do you have any logs or timeslips that highlight that?Silas Stephenson wrote:When I got my car back from a good old carbon clean, it pulls much stronger and more responsive in the lower rev range so I don't think its all top end performance were the gains are from
My carbon is back :-(
Re: My carbon is back :-(
God no im not that tech minded, but i have owned the car for 4 years, and know the car inside out, and it is def alot nicer to drive, even the exhaust note is stronger, if i keep the car it will be done again after 20,000 miles
What I've done is had the dealer manually clean the valves. I then prior to ever oil change use a induction cleaning kit from 3m. I'm hoping this will slow down the buildup process
http://www.youtube.com/watch?v=RX5J5kZL ... r_embedded
Wynns makes a similar product for you guys in the UK
http://www.amazon.co.uk/Wynns-Petrol-Di ... B005QB0SM8
I'm changing my oil every 5000 miles, as I think this will also help in limiting the carbon buildup+ also will try the wynns
Users browsing this forum: No registered users and 95 guests
