Swopping ipod doc for cd changer
Hi Guys
Im going to swop my ipod doc in my glove box for a cd changer.Has anyone ever done this? if so how easy is it to do?
Thanks for any help
Rich
Thanks for any help
Rich
Re: Swopping ipod doc for cd changer
I swapped the other way, is dead easy - literally a 30 second job. I think you don't even need keys to remove the iPod dock either. Once is pulled out is just one multi-plug to disconnect, reconnect & push the CD Changer into the dash. You will need keys if want to remove the CDC again for sure.
Do you need VCDS to do any recoding ?
Do you have the CD changer ? if not may be able to swap my CD changer for your ipod dock
Can we have the multi cd and ipod ?
I have the multi changer but an ipod would be cool aswell as
Drive low,park lower
It doesn't need recoding, but will register an error as the iPod dock is actually for later cars (I know it was in the brochure at one point) so it is seen as no-communication or similar.spikeyboy101 wrote:Do you need VCDS to do any recoding ?
Not in the GB, I think there is a Dension system that allows them both to work or you can hook up an aux in connection to the RNS-E & use that as an additional input source but that won't charge the iPod although can use anything then.Jules wrote:Can we have the multi cd and ipod ?
Kufatec sell a kit or you can buy the plugs from Audi & make it up you will need VCDS to code the RNS-E to accept the new input though & think is the TV connector so may interfere with some future upgrade plans.
Edit - here is a link to the Kufatec product - http://www.kufatec.de/shop/product_info ... RNS-E.html
DIY - http://audiretrofit.quinlivan.net/rnseauxin
MB2 wrote:Not in the GB, I think there is a Dension system that allows them both to work or you can hook up an aux in connection to the RNS-E & use that as an additional input source but that won't charge the iPod although can use anything then.Jules wrote:Can we have the multi cd and ipod ?
Thanks for the reply mate,i'll certainly look into it
No problem - have added link to Kufatec & DIY options for you. Looking at the DIY link you can probably pin it into the TV adapter so probably not such a problem. I bought the Kufatec kit when ordering some other stuff from them.
Audi also make an iPod adapter that replaces the CDC which charges the iPod & gives some control from the HU but it seems to be universally hated. Ex had a VW & quite liked it so is probably not the best solution but compared to an iTrip is good !
Thank for your help guys,was a very easy job and didnt take very long at all.
Hi can you tell me where I could get a ipod connector dock from please? never use the cd changer
I bought mine on eBay, got lucky & only paid 20 for it but they don't seem to go for an awful lot anyway, as isn't much to them so seem to be much cheaper than a CDC.
£50 and you can have mine
maybe interested in that send me a PM
Users browsing this forum: Google [Bot], N9ATH and 112 guests
