P_G wrote:Si, I won't be tracking mine so will it be OK to use EBC YS's on these discs for road use?
yes id say so or DS2500 as are a bituminous based pad, we have a big range of pads we can spec for your ideal use.. can even make bespoke pads
Yes i too have same prob on my OEM discs, ive found that pad choice makes a difference in terms of how quickly, if you look the AP disc holes they are counter sunk and are 1mm bigger and the AP rotors have 48 17mm axial vanes unlike the OEM, so effectively venting or blowing the holes clean as such in use/rotation .. but this build up really depends on pad material and conditions and use.TimDogg wrote:Are the holes bigger than OEM, mine get filled in all the time?
+1RS4POWER wrote:Are you also offering lightweight rear rotors?
