Car hesitates in 1st and 2nd, input appreciated !
HeavyTraffic
Post by HeavyTraffic » Mon Feb 06, 2012 8:01 pm
The car is used daily and has been running well. Took it out on Sun and no problems getting to my destination. On the return journey the car was hesitating changing from 1st to 2nd and from 2nd to 3rd, after getting through the gears it sat happily at 70. Part of the road has average speed cameras where I often use the cruise control but on this occasion it would not engage. I tried it another couple of times afterwards with no joy. On start up the DIS states OK but the start button now requires to be held down until engine fires where as before a light press would have the engine turn over until it started. All this in one afternoon ! Thanks in advance for your input. I"m not a frequent poster but always reading and learning.
PetrolDave
Re: Car hesitates in 1st and 2nd, input appreciated !
Post by PetrolDave » Mon Feb 06, 2012 8:17 pm
Faulty clutch switch - the start button requiring to be held down is the convincer.
HeavyTraffic
Post by HeavyTraffic » Mon Feb 06, 2012 8:41 pm
Thanks Dave, is the clutch switch responsible for all the symptoms listed ?
adsgreen
Post by adsgreen » Mon Feb 06, 2012 9:25 pm
Yup.
However weirdly the cruise control and the starter button IIRC utilise two different switches. Very easy to replace and cheap
HeavyTraffic
Post by HeavyTraffic » Mon Feb 06, 2012 9:32 pm
Cheers Ads, will get it booked in and sorted..
adsgreen
Post by adsgreen » Mon Feb 06, 2012 10:01 pm
It's a dead easy job to do - hardest part is arranging yourself to get behind the pedal box :)
just quarter turn old sensor, unplug, plug in now one and quarter turn back in place.
BruceBanner
Post by BruceBanner » Tue Feb 07, 2012 7:14 am
@Heavytraffic - I think I am having a similar problem. Does it feel really notchy going into 1 st and 2 ? Almost like the clutch is on its way out?!
scaghead
Post by scaghead » Tue Feb 07, 2012 7:56 am
HEAVY TRAFFIC...defo clutch pedal switch mine had same issues last year....bruce banner the thing i noticed when my clutch pedal switch went, was as you changed gear the revs held slightly before dropping ..if your cruise control does not work and your having to hold down the start button for car to start then clutch pedal switch..
HeavyTraffic
Post by HeavyTraffic » Tue Feb 07, 2012 9:21 am
Bruce, when accelerating to change up the power feels like it drops off when i release the clutch before it picks up and goes. Repeats process from 2nd to 3rd. Could be interpreted as slipping i suppose.
Cheers scaghead and all posters, now confident its not a big job.
spikeyboy101
Post by spikeyboy101 » Tue Feb 07, 2012 2:22 pm
It could be the torque limiter in gears 1 - 3.
If your doing it under hard accelleration and changing quickly at high rpm it feels like the power is being pulled back.
Answer is to tame the change up in these gears
adsgreen
Post by adsgreen » Tue Feb 07, 2012 5:15 pm
Not sure about the torque limiter as thats only below 5k rpm ish - a full throttle / big power change it should keep above that.
However if you've got the ESP / Traction control on and are a little brutal with the clutch and throttle its very easy (esp this time of year being cold and damp) to trip the traction control into cutting back power. It's a very odd feeling and I would agree that clutch slip is quite a similar sensation.
In higher gears the gearing means the chance of tripping the tc is much lower so isn't noticable. Try it with ESP off (or even part off) and see what happens.
BruceBanner
Post by BruceBanner » Tue Feb 07, 2012 10:06 pm
Mine has got worse today. Booked in for a road test with a technician at Halesowen Audi on Friday. If it is diagnosed as the clutch failing will they sort it out FOC as the parts are under the 1 year standard warranty? Had it fitted last July by an independent, but all parts were OEM from TPS.
HeavyTraffic
Post by HeavyTraffic » Wed Feb 08, 2012 2:54 pm
New clutch switch fitted this morning. All symptoms gone and back to her old self. Thanks again for all input. HT
rs4blacked
Post by rs4blacked » Wed Feb 08, 2012 3:35 pm
BruceBanner wrote: If it is diagnosed as the clutch failing will they sort it out FOC as the parts are under the 1 year standard warranty? Had it fitted last July by an independent, but all parts were OEM from TPS.
Am surprised at that as the part is NOT OEM as not supplied by Audi.
When I worked in the motor trade Car Dealers and manufacturers only covered the cost if the car was supplied by them and not from places like TPS or ECP as they are NOT OEM.
Currently Mondeo ST155 & Titanium X Sport
RS4 Phantom Black, Black Optics, Tech Pack, Milltek Non Res Non Valved
adsgreen
Post by adsgreen » Wed Feb 08, 2012 4:29 pm
The switch might have been bought from Audi dealer parts dept so should have a form of warranty.
Users browsing this forum: No registered users and 65 guests
