Oh pants, car already feeling slower......
Re: Oh pants, car already feeling slower......
Post by Shoppinit » Wed Jan 18, 2012 8:38 am
It would be interesting to see what difference the Wagners make in performance terms on a highly modificed car. On a standard car they make no difference.
If heat soak is your concern then better intercoolers seems like a no-brainer to me.
Daveperc
Post by Daveperc » Wed Jan 18, 2012 9:12 am
Hi Shop
Surely that;s because without adjusting the map there is no way to take advantage of the freer flow of cooler air. On a mapped car the inlet pressure can be tweaked to take advantage??
Post by Shoppinit » Wed Jan 18, 2012 9:17 am
It's just that at the low boost pressure of a stock map doesn't create very high charge temperatures, so the standard IC are correctly dimensioned for a standard car. When you run higher boost, you drastically increase the charge air temp and that's where you see the benefit from the larger heat transfer surface area of the Wagners.
Post by bam_bam » Wed Jan 18, 2012 9:26 am
The Wagners weren't on my shopping list as my standard ones were fairly new and not leaking. But because I've got 60mm intakes, the standard ICs would actually become a restiction. The Wagners just flow a lot better and in most cases (modified cars) actually give an extra 20-30HP.
Post by Shoppinit » Wed Jan 18, 2012 9:34 am
The Wagners are good value for money, especially if you get them without the carbon shrouds; They are barely more expensive than the OEM crap.
Mr Footlong
Post by Mr Footlong » Wed Jan 18, 2012 12:43 pm
the carbon shrouds are a bit oversized compared with the OEM shrouds that have to be modified non?
Current:
Gone:
Post by bam_bam » Wed Jan 18, 2012 12:50 pm
Not bothering with the CF shrouds.
Ryan_Pestell
Post by Ryan_Pestell » Wed Jan 18, 2012 1:14 pm
im looking forward to seeing the bonnet also, you had it stamped of vents stuck on?
quite like the idea of stamps but unsure if the 6 could pull it off.
Daytona RS6+ Sold :(
Now Building a 500HP Lotus Exige
Post by Shoppinit » Wed Jan 18, 2012 1:28 pm
The OE shrouds have to be modified. I did mine with a stanley knife.
speedtrapped
Post by speedtrapped » Fri Jan 20, 2012 4:02 am
bam_bam wrote:
speedtrapped wrote:As for trans, I have a custom level10 trans, able to handle 800hp. Extra clutch packs, hardened internals, bigger valve body. In addition to their TC.
Hi Stephen,
When was your trans built up, was it before Sam left to form 517trans?
Also, would you mind posting up a dyno of your beast in current tune? It'd be interesting to see what torque you're running, HP is nice but it's the twisting stuff that kills the 'box.
The trans was built 14 months ago, so no...I think Sam may have left. That said we, as in a group of Audi owners are doing a Maha dyno day, w/in month. I will post up mid feb.
Btw, the pic of the sport tec mod is half right, everyone that does the mod uses a galvanized wire mesh, as I have. I have run the vents for over a year, snow, rain debris no issues. Also as mentioned, meth, meth, meth...it's insane when dialed into the tune.
C5 RS6-DBR Stage 3 Race kit, with lots of other bits and pieces.....
11' CTS-V Wagon, Stage 2 545/590 RWP, Grocery Hauler and Avant pacifier.....
speedtrapped
Post by speedtrapped » Fri Jan 20, 2012 4:04 am
I run wagners, and run 24 psi, what would u like me to log? When I get chance I can post up.
perthwaRS6
Post by perthwaRS6 » Fri Jan 20, 2012 9:21 am
for those interested, visit V8weight post of 29 March 2010 at
http://www.rs6.com/showthread.php/20630 ... ht=cooling
if you wish to see the modified sport tec undertray cooling vents with screens and 'how to do it yourself' drawings and instructions. Screens a must to quote V8weight "It said on the package it should repel not only stray rocks and road debris, but also chickens and rabbits."!
V8weight post very helpful. This undertray mod is highly recommended for warm weather conditions.
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
Mr Footlong
Post by Mr Footlong » Fri Jan 20, 2012 9:58 am
Bugger, I had read various threads on the mod but not that one. I might look at getting a spare undertray and run a vented/meshed one for the warmer months and swap back to full for the cooler ones. Will give it a while and see how I get on with the heat soak on prolonged runs I guess.......
Current:
Gone:
Post by Shoppinit » Fri Jan 20, 2012 10:02 am
Wouldn't back facing louvers be a neater solution?
Post by Shoppinit » Fri Jan 20, 2012 10:03 am
Users browsing this forum: 2014audis8 and 77 guests
