Help please.... Update P5. She's back :)
Re: Help please.... No turbos :(. Update pg 2
Post by bam_bam » Sun Jan 08, 2012 5:17 pm
I thought this was due to a broken manifold, can oil starvation cause this?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Sun Jan 08, 2012 5:52 pm
if it is the manifold that has caused the failure then they can collapse and turn so causing high egts and turbos to pop originally - then the manifolds got worse and broke and caused it to seize.
http://www.MRCtuning.com
Imola_Sid
Post by Imola_Sid » Wed Jan 11, 2012 4:48 pm
Thanks for the replies.
Fingers crossed the turbos/manifolds will be removed over the weekend. If the manifolds are at fault then i've got some standard ones sorted thanks to Luke.
I'm trying to keep costs to an absolute minimum. I'm currently setting up a business, just bought a house, spent a sh!t load on extending it etc so funds are very low. If all goes well with the self employed route/new business, i'll be spending a good whack on getting more power out of this beast. It's all a bit uncertain at present, a bit scary to be honest.
I'm not sure what to do re the gearbox. When Kim (QST) worked on the car last he told me to leave it as it is and keep driving it until it fails as it was driving fine and rarely fails to engage into reverse. He said it could go on for a long time and it wouldn't damage anything else when it does completely give up. I'm thinking I may just leave it for now. But if I do decide to fix it, the ZF sounds the best to me.
Ben, the turbos were changed about 5k miles ago/1 year ago. But I think used units were used (apparently off a low mileage car). At the same time; the timing belt, water pump, thermostat, MAFs and a whole load of other stuff was done. There's a reciept for a good £6k spent IIRC. The gearbox was meant to be have been done by Mr Transmission at the same time IIRC.
What would I be checking re oil starvation?
Post by chunky79 » Thu Jan 19, 2012 11:07 am
whats the score then sid? good(ish) news or not?
dunc
Imola_Sid
Post by Imola_Sid » Tue Jan 24, 2012 9:35 pm
Haven't managed to take it apart mate.
It's parked up in my drive and will be for a while. Too many other commitments at the moment unfortunately. As much as I love the car, need to be grown up for a change and spend the money wisely (the business comes first this time :shock: sh!t man! I'm sounding like an old man :lol:)
As soon as things settle down, i'll get the car taken apart to see exactly how much damage has been done. I think used manifolds and reconditioned turbos will be the most likely solution.
For now i'm running a proper banger as a workhorse (a mates old Peugeot 306! :oops: - can't believe I just admitted to that hah), but I regularly drive my brothers E39 M5 so I get my dose of power when needed :twisted:
mavada
Post by mavada » Thu Jan 26, 2012 11:31 pm
by Imola_Sid » 24 Jan, 2012 - 20:35
http://www.ebay.com/itm/300655124989?it ... fd&vxp=mtr
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
grizz
Post by grizz » Thu Jan 26, 2012 11:35 pm
Cheap <beep> chinese copies ..... keep clear .
Unit 20
0151 3366888
Post by Shoppinit » Fri Jan 27, 2012 9:11 am
Imola_Sid
Post by Imola_Sid » Fri Jan 27, 2012 9:40 am
:lol:
Imola_Sid
Post by Imola_Sid » Tue Apr 10, 2012 6:03 pm
Quick update guys....
Engine has been taken out, manifolds & turbos have been removed.
One manifold is broken on the inside (see pic), the other seems fine.
One turbo is seized and the other is spinning - i'll be sending them of for a re-con.
Any ideas what would cause the turbo to seize (the blades seem fine) :?
Re: Help please.... No turbos, Update pg 4 turbos/manifolds
Post by Shoppinit » Tue Apr 10, 2012 6:05 pm
Porbably bits of manifold jammed in there somewhere. Wouldn't take much of an impact to bend the blades and cause them to jam against the body.
Where's this photo then?
Imola_Sid
Post by Imola_Sid » Tue Apr 10, 2012 6:06 pm
Photo uploaded...
Would the turbo blades not break?
Post by Shoppinit » Tue Apr 10, 2012 6:10 pm
I think your only concern is whether the turbo has seized from oil starvation. This is the second set of turbos on the car now, so it's a legitimate concern. The bearing journals will tell you the story of what's gone on there, but it's a bit of a coincidence that the manifold's broken AND a seized turbos. Occam's razor and all that.
Post by chunky79 » Tue Apr 10, 2012 6:10 pm
I would have thought you would see some kind of damage to the blades. Was there oil up to the seized turbo Sid?
Post by Shoppinit » Tue Apr 10, 2012 6:14 pm
I'm assuming that the seized turbo is on the side that the mani is broked?
Users browsing this forum: 111marc111, Google Adsense [Bot], rs4wagon and 63 guests
