MMMMMMH Help PLEASE
delboymafia
MMMMMMH Help PLEASE
Post by delboymafia » Thu Dec 15, 2011 6:57 pm
http://i193.photobucket.com/albums/z240 ... C00549.jpg
Hi all, when ever i start the beast up first time in the morning i get this signal come up, it only appears once (always on first start up), it beeps a few times then goes. I was wondering is it my tyre pressure sensors or my brake pads getting low. In the book it says brake system failure :( . Any help or thoughts are greatly appreciated. Thanks. Chris.
MEV
Re: MMMMMMH Help PLEASE
Post by MEV » Thu Dec 15, 2011 7:07 pm
ah ha!! Ive had that a few times and worked out that if I put my foot on the brake on ignition but dont take it off and select gear straight away then it warns me with that same thing! I suppose it's senses the brakes being locked..... Any way if I remove foot from brake and then apply again before gear select its fine and comes up OK. Try that or just dont touch the pedals on ignition..but do so when selecting gear
B7 RS4 - 07 Phantom, Silver leather, 59k. Current
B5 RS4 - 01 Avus, B7 Brake kit, Miltek cat back, Sroof, leather, optics. 66k. Current
B8 RS4 - Sepang, BO, Roof, Sports Sold
C5 RS6 + # 296 Ebony black, full optics, titans, carbon and natural leather - sold and missed
B7 RS4 Avant Daytona Pearl, black optics, SS+, buckets, privacy. Sold
B5 RS4 - MRC 420. Gone but not forgotten.
Post by Shoppinit » Thu Dec 15, 2011 7:09 pm
Watch out for those exclamation marks.
Have you checked your brake fluid level. I think it can only be that or the pads.
Mine does this sometimes when I leave the car out and the temperature goes below zero. I just ignore it. Yours sounds more systematic though.
MEV wrote:ah ha!! Ive had that a few times and worked out that if I put my foot on the brake on ignition but dont take it off and select gear straight away
Interesting! I'm going to try that.
Post by Shoppinit » Thu Dec 15, 2011 7:12 pm
Correction, the pads have a different symbol. Just brake fluid level then, or MEV's thing :)
MEV
Post by MEV » Thu Dec 15, 2011 7:25 pm
Process of elimination, as also had fluid and pads checked on MOT (at least 5k on them) and since then it hasnt done it again. :)
bakustax
Post by bakustax » Thu Dec 15, 2011 7:32 pm
It's low brake fluid ...99%..had the same and topped up the fluid...not seen it since
delboymafia
Post by delboymafia » Thu Dec 15, 2011 8:41 pm
Wow cheers for all your help, knew i could rely on you chaps. Checked the brake fluid level its full. Hoping its just like what MEV says, i park in my garage on a slope so i always use the brake. If not maybe i should take it to the garage and ask them to look at brakes!! Chris.
drybeer
Post by drybeer » Thu Dec 15, 2011 9:29 pm
Shoppinit wrote:Watch out for those exclamation marks.
Interesting - mine did this a couple of winters ago when doing first daily starting in really sub zero conditions...
I also found my power steering noisy when cold, so diagnosed low PAS fluid levels - but I cannot for the life of me think where the fluid went to?!?!
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
Keihin
Post by Keihin » Fri Dec 16, 2011 12:59 am
Hi.
You should check your servo oil level as well. It also triggers this error as the brakes are assisted by the servo pump.
posterboyj
Post by posterboyj » Fri Dec 16, 2011 7:58 am
Simple fix
If there is a fuse box on the battery, give the connectors a clean
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
Rupert
Post by Rupert » Fri Dec 16, 2011 9:19 am
MEV wrote:ah ha!! Ive had that a few times and worked out that if I put my foot on the brake on ignition but dont take it off and select gear straight away then it warns me with that same thing! I suppose it's senses the brakes being locked..... Any way if I remove foot from brake and then apply again before gear select its fine and comes up OK. Try that or just dont touch the pedals on ignition..but do so when selecting gear
I've had it a few times and only when I'm in a rush... I've worked out that it is due to low battery voltage after startup. If I move to D straight away it is likely to appear, but if I wait a second after starting and then select D it will never show.
delboymafia
Post by delboymafia » Fri Dec 16, 2011 2:03 pm
Ok chaps, went to the beast today, started up, left it running for a min or so, then bingo selected D, no warning light. Thank you all for your help. Chris.
MEV
Post by MEV » Fri Dec 16, 2011 2:50 pm
Rupert - sounds like a soltution this as had my babe looked at today for a new key configuaration ( Timpsons @ £132 ) and it did show on his fault checker as being slightly low on voltage 11amps. So that figures when I start up quickly and select gear it also gives me the bird! So Delboy check you battery voltage also.
Post by Shoppinit » Fri Dec 16, 2011 3:01 pm
Might explain why when it's particularly cold it does it too, because the battery will give out less voltage especially having just been used to start the engine.
Users browsing this forum: Lander91 and 67 guests
