Silver trim
Everything you need to know about cleaning products and general car care
KernowPete
Silver trim
Post by KernowPete » Wed Dec 14, 2011 1:49 pm
Yeah I know its been done to death but is there any latest thinking on the milky discolouration on the silver window surrounds? Has anybody successfully restored theirs? Mine bug me every time I look at them.
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
P_G
Re: Silver trim
Post by P_G » Wed Dec 14, 2011 1:54 pm
Autoglym super resin polish.
KernowPete
Re: Silver trim
Post by KernowPete » Wed Dec 14, 2011 6:32 pm
Thanks P_G but I tried that and it made bugger all difference. Or maybe I just didn't apply enough elbow grease??
P_G
Re: Silver trim
Post by P_G » Wed Dec 14, 2011 9:12 pm
Blimey, they must be bad then.
KernowPete
Re: Silver trim
Post by KernowPete » Wed Dec 14, 2011 9:38 pm
P_G wrote:Blimey, they must be bad then.
Possibly, but I'll give it another go and see if I can make it work second time around.
andre3k
Re: Silver trim
Post by andre3k » Fri Dec 16, 2011 12:50 pm
I had an isssue with something else but decided to throw the qurestion at a pro:
Hi Dre, I hope you're well. Yup, the performace of the nano-sealant is something we get a few enquiries about especially as it were after application. The problem is the contact surface, which should remain as near to water - nano-sealant application as is humanly possible. Unfortunately, as the windscreen sees daily use a layer of grime tends to build up between this 'ideal' contact layer and as a consequence the performance drops off. Not to worry though the foundation is perfectly solid and simply needs to be restored by removing the accumulated layer of grime. It's been a good 3 or 4 weeks since the cold-weather treatment, so given you haven't 'maintained' :-) the car it sounds like this maybe the problem. Feel free to swing by and we can sort that for you; alternatively, give it a clean and wipe down with the IPA we gave you and all should be fine.
Pertaining to your friend and the trim problems, ideally we'd like to see it to understand what's going on as we didn't encounter anything like that with your car nor have we on other Audis. Having said that it was only in for a winter-prep treatment so the aesthetics were somewhat secondary. Still, I'll have a chat with Profaci when he gets back from hols as he worked on your car.
The SRP though I'm struggling with...there's nothing inherenet in SRP that would lead me to believe it would be useful in this instance. If it is what I think it is then this milking is probably a result of acids used to prepare trim for dressing or more
likely as part of an ill-advised wash routine. In my experience a chemical action cleaner would be best like the Klasse or Werkstatt products (prob Wekstatt as it's easier to get your hands on); an abrasive polish would likely do more harm than good. SRP has resins with no real chemical action about it, includes abrasives (although very minor) and has a high filler content. None of which are characteristics I'd naturally think would assist. That being said sometimes it's all a bit like cooking where stuff is put together which makes no sense but still tastes delicious ;-)
If he/she is in the area tell them to come by the workshop so we can take a look; I'm quite intrigued. Otherwise, if they want to have a go themselves tell them to try an application of Prime on its own or Prime worked in with light-cut pad if the former doesn't yield the result.
All the best for Xmas
Kind regards,
Lanré.
_______________
Drayke Fields Ltd.
M +44(0)7790 575 575
T +44(0)121 373 3743
E lanre@draykefi
Return to “Cleaning & Car Care”
