CAT and Engine block damage - advice please
Re: CAT and Engine block damage - advice please
Post by Shoppinit » Wed Dec 14, 2011 10:26 am
The EGT (exhaust gas temperature) sensor has a big impact on the fuelling, but if it (or the mixture) was that far out of whack, then you'd have other DTCs come up.
Unless they are talking about the lambda / O2 sensors? They need to be a bit more specific.
P0741 is the same as 17125. TC not locking up. Could be ATF level. I suspect the £4k they are talking about is for the part only.
They need to stop diagnosing problems by sticking their finger in the air. To check the car, get out logging the MAFs and fuelling with a Vagcom or similar OBD2 reader.
GaryCollinson
Post by GaryCollinson » Wed Dec 14, 2011 12:01 pm
Yep 4K part only. Just checked. Gulp.
This is Audi so they should be using the Vagcom. I'll get the level checked and hope its just a minor problem
Post by Shoppinit » Wed Dec 14, 2011 12:07 pm
You might as well change the ATF. At least that way you can evaluate the condition of what's coming out. That will give you an indication of the box's health.
They will have diagnostics gear, but be too lazy / incompetent to take it out on the road in the car. And less likely to be able to evaluate the data.
JCviggen
Post by JCviggen » Wed Dec 14, 2011 2:40 pm
Probably the gearbox code has been there for some time and you simply haven't noticed. And if you didn't know you'd probably motor on for many more miles not noticing anything wrong. Ignorance is bliss sometimes. Not so much with the EGT issue, that can ruin your cats.
B7 RS4 saloon Misano red, comfy seats, JHM tune & JHM full exhaust with cats and resonators - gone.
C5 RS6 Avant Daytona/Cognac - gone.
981 Cayman GTS Gray/Orange.
My youtube
Users browsing this forum: steve2003rs6 and 83 guests
