Auxiliary Radiator Delete
Re: Auxiliary Radiator Delete
It has a fair bit more grunt than yours already though Glenn due to the race cats and full hi flow stainless steel exhaust?
- Revolution
- Trader (Expired)
yes, also driven it previously before he started at it again.
It was probably the last time the weather was decent and no rain was due
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
How you been finding the cold air feed?
After Luke asked about this i thought we could bump it up,have you got a picture of the engine bay Caldy,it would be nice to
see it close up with the red pipes and paint work
Drive low,park lower
During cold air feed installation
Pre Catch CAn
Post Catch Can
Pre Catch CAn
Post Catch Can
RS4 B7 Phantom Black
Thanks Caldy
That looks really good,loving the screen wash cap etc,how is the paint holding up and i'm guessing it was a special
heat resistant paint used
Hows the CAF holding up also?
Everything working:
Catch can a waste of time - virtually empty but as I didn't split original hoses I can revert to stock
Manifold was powder coated - paint still perfect
Cold air feed fine but I'll change it over the winter and smarten it up by making a mould for the grille- it's the only part that you can see. Oil temps rise to 105+ when pressing on but quickly fall back
Caps are from jcapsonline.com
cool, so no real negative effect on the car being one aux rad down
I was going to ask what the can caught...caldy wrote:Everything working:
pretty much water? with a bit of oil? or basically nothing at all?
and the can still fed the cyclone seperator?
Correct Arthur - can is virtually empty. It's in series between the valve covers and the cyclones.
thanks, interestingcaldy wrote:Correct Arthur - can is virtually empty. It's in series between the valve covers and the cyclones.
sounds like the valve cover baffles are pretty effective, and what little that does get through is reduced further by the cyclone
blow-by can't be much of a factor at all in deposit formation
There is enough space to relocate the aux radiator ->
So long,
Sebastian from Germany
So long,
Not sure you'll gain much there. The main radiator is the same circuit as the aux so putting one infront of the other doesn't feel right.
Holy thread revival!
Users browsing this forum: No registered users and 169 guests
