anyone changed a starter motor???
neastev
Post by neastev » Sat Nov 19, 2011 10:39 pm
Hello all
Starter has been sounding a bit lazy and been a bit intermittent over the last week or so. Yesterday, car wouldnt turn over so need to get it out and replaced. Anyone know if its a nightmare before I scrape the rust off the toolbox........... :boohoo:
Just read through previous posts and "holy <beep>" it says engine out :drink: has anyone ever done the starter in place??? Hope its possible....... :audibash:
Daveperc
Re: anyone changed a starter motor???
Post by Daveperc » Sat Nov 19, 2011 11:06 pm
You sure it's not the battery??
neastev
Post by neastev » Sat Nov 19, 2011 11:21 pm
Hey Dave
Yeah, tried jump leads with another car, no joy...... It had been running fine 20mins before, got backin and "click". It has been intermittent until now...............................
Post by Shoppinit » Sun Nov 20, 2011 2:43 pm
It's a bugger of a job. In theory it's an engine out job, but I seem to remember that grizz had a way of changing it in-situ.
hahnmgh63
Post by hahnmgh63 » Fri Nov 25, 2011 6:51 pm
I just re-installed my engine/tranny after some work and can say that it can be done with the engine in the car although I think you will need to drop the whole package with the subframe down a few inches to get at it, plus other items to be removed like the oil filter, cooler lines, etc.. One of the starter bolts needs to be accessed from the tranny / Bell housing side which will be the tough one to do (hence, part of the reason for the subframe package drop).
neastev
Post by neastev » Mon Nov 28, 2011 10:53 am
Thanks for that, :thumbs:
I changed the cam belt, water pump, tensioners, roller etc at the weekend but not put the carrier back on yet as I had to look at the starter. Have the intercooler pipes off and oil filter is out the way but there is no access to the bolt from the Trans side..... Will look at the subframe next...... hopefully that will give me the space so I can get the car back on the road soon.....
thanks again for the info, as I now have some hope that it can be done as I dont want to pull the engine... maybe get some sleep tonite :shock:
Maximo
Post by Maximo » Mon Nov 28, 2011 2:18 pm
Having just changed my battery, I would get that checked first before heading down the starter motor replacement route. Although you've said that you tried a jump start and that didn't work, remember these cars need alot of power to turn over. Had it in the past where the car wouldn't start and a jump start didn't work, replaced the battery and hey presto all running fine again.
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
js
Post by js » Mon Nov 28, 2011 2:29 pm
If you decide you do need to change the starter, and do not yet have one then I have a spare used one if you like, which was sold as working perfectly to me.
£40 + postage.
neastev
Post by neastev » Mon Nov 28, 2011 6:01 pm
Swapped the battery already and it is definately the starter, its locked or siezed. When it failed, it started to turn the engine then something "cracked" and then "click" everytime. Eventually got to the starter and can see the housing is cracked where the bendix gear is......... Starter has sounded like an old school Mini since I got the car so I think the bearings have cratered....
Going to tackle the subframe tonight so fun and games...
JS- sent you a PM regarding starter, cheers
thanks gents
Post by Shoppinit » Mon Nov 28, 2011 6:02 pm
Have you checked your cambelt?
Edit: never mind, didn't read your post properly :)
Post by chunky79 » Mon Nov 28, 2011 7:26 pm
hope the starter ring is ok if it has been bad for that long
neastev
Post by neastev » Mon Dec 05, 2011 10:51 pm
well im happy to report that it is possible to change the starter with the engine still in the car, although it is a total effin nightmare....................
Finally got the engine started yesterday and all is well after the cambelt. Finished buttoning up bumper etc today and took the car for a run...... what a difference the cam belt change has made, much better response smoother running. Well pleased :biggrin3:
Mr V10
Post by Mr V10 » Tue Dec 06, 2011 3:29 am
Really? A cambelt change made that much difference? Wish mine did !
Post by Shoppinit » Tue Dec 06, 2011 9:26 am
If it made a difference it would mean that it wasn't done correctly last time. Some people change the belt without the proper tools. You can't install the new belt properly using tipex.
Post by Shoppinit » Tue Dec 06, 2011 10:25 am
Good news about the starter motor. What did you have to do to access it?
Users browsing this forum: Bing [Bot], Google [Bot] and 83 guests
