Retrofit RS4 buckets.... Please Help info needed
otterolly
Post by otterolly » Tue Nov 08, 2011 1:38 pm
Hi guys
I have retrofitted some buckets in place of the comfort recaro's and I am having a small issue.
When fitting the passenger side seat I noticed that there was no black plug on the wiring loom that plugs into the floor ?? I believe that this is the plug for the pressure plate for the seatbelt warning chime, but when I fitted the drivers side seat the black plug was present ??
Upon turing the car on I get an airbag warning light ? The seatbelt pressure plate works correctly on the drivers side ie. the light comes on until the seatbelt is inserted, but no light on when sitting in the passenger side ???
I am going to run Vag Com on wednesday night to see what the fault code says but any info in the mean time would be great
Should the black plug be present on the passenger side seat ?
thanks in advance
sonny
Post by sonny » Tue Nov 08, 2011 2:09 pm
That will be for the side airbags, buckets seats don't have it. You should have fitted a by-pass plug to the air bag socket. Recaro do one for after market buckets. You may need Vag Com to reset air bag warning light
Jules
Re: Retrofit RS4 buckets.... Please Help info needed
Post by Jules » Tue Nov 08, 2011 3:52 pm
sonny wrote:That will be for the side airbags, buckets seats don't have it. You should have fitted a by-pass plug to the air bag socket. Recaro do one for after market buckets. You may need vag com to reset air bag warning light
Exactly right,Lee (mutantfatcat) has done this,maybe worth a pm
Drive low,park lower
mutantfatcat
Post by mutantfatcat » Wed Nov 09, 2011 12:11 am
sonny
Post by sonny » Wed Nov 09, 2011 12:30 am
These are the resistors used by Recaro http://forum.rs246.com/download/file.ph ... &mode=view
otterolly
Post by otterolly » Wed Nov 09, 2011 8:19 am
Thanks guys I'll check that out :)
mutantfatcat
Post by mutantfatcat » Wed Nov 09, 2011 7:35 pm
Oh forgot to mention, no black plug on the passenger seat is correct. If both seats have the small yellow plugs, the resistor is already fitted within the wiring loom of the seat, so no additional resistors required.
Just reprogram the airbag module as stated in the link above and job done.
otterolly
Post by otterolly » Wed Nov 09, 2011 11:01 pm
Thanks mutantfatcat, the seats have the yellow airbag plugs fitted to both seats so looks like all I need to do is hook it up to Vag Com ;)
mutantfatcat
Post by mutantfatcat » Thu Nov 10, 2011 1:35 am
otterolly wrote:Thanks mutantfatcat, the seats have the yellow airbag plugs fitted to both seats so looks like all I need to do is hook it up to vag com ;)
Absolutely correct.
otterolly
Post by otterolly » Sat Nov 12, 2011 3:03 pm
:wink: got it sorted now.....thanks again mutantfatcat :wink:
mutantfatcat
Post by mutantfatcat » Sat Nov 12, 2011 8:14 pm
otterolly wrote::wink: got it sorted now.....thanks again mutantfatcat :wink:
glad I could help!
PJC
Post by PJC » Sat Nov 12, 2011 11:08 pm
That's what this forum is all about. :beerchug:
ArthurPE
Post by ArthurPE » Sat Nov 12, 2011 11:13 pm
didn't happen without pics :D
Users browsing this forum: Google Adsense [Bot] and 115 guests
