Gearbox question
DRC
Gearbox question
Post by DRC » Fri Oct 07, 2011 12:08 pm
Hello RS6 experts,
Has anybody had the following C5 RS6 gearbox issue? No doubt the local audi garage will just want to replace the whole gearbox, but I'm curious as to what could be wrong before I approach them...
When putting the car into gear for the first time after engine startup, one of two things happens occasionally:
1) The gearbox goes into fail mode, where I'm restricted to one gear and the indicator on the dash lights up all the gear symbols.
2) The car won't change out of first gear when moving forward, although there is no error indication on the dash.
In both cases, turning the engine off and on again restores things to normal.
Any ideas?
Re: Gearbox question
Post by Shoppinit » Fri Oct 07, 2011 12:16 pm
Sounds more like a problem with the F125.
Vagcom will help you diagnose.
http://www.audipages.com/Tech_Articles/ ... place.html
DRC
Post by DRC » Fri Oct 07, 2011 12:29 pm
Great info! Thanks!
That it could be something outside the gearbox is promising indeed. I'm sure it will be awkward to get at though. :)
Right, just need to get hold of Vagcom.
Post by Shoppinit » Fri Oct 07, 2011 12:33 pm
If it's not that, it could be a problem with your gear selector lever. Again, all this can easily be tested with the Vagcom.
DRC
Post by DRC » Fri Oct 07, 2011 12:52 pm
Thanks again.
To be honest, the last time I used Vagcom a few years ago, I couldn't make much sense of it. With a new gearbox at stake, this time I'll be reading the instructions. :)
Post by Shoppinit » Fri Oct 07, 2011 1:28 pm
It's peasy easy. I'll walk you through it.
Post by bam_bam » Fri Oct 07, 2011 4:37 pm
DRC has to be the most tragic choice for a username on the C5 RS forum... I'd consider changing your username to "Coilover", don't forget to renew your topmounts while you're at it.
el_ringo
Post by el_ringo » Fri Oct 07, 2011 7:53 pm
bam_bam wrote:DRC has to be the most tragic choice for a username on the C5 RS forum... I'd consider changing your username to "Coilover", don't forget to renew your topmounts while you're at it.
:beerchug:
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!! :( ****
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
DRC
Post by DRC » Fri Oct 07, 2011 8:12 pm
Well, I couldn't think of a better username at the time, so went for irony.
I had my DRC swapped out with PSS9s back in 2007.
grizz
Post by grizz » Fri Oct 07, 2011 8:25 pm
The f125 is a little harder on the rs6 as the down pipe is in the way , It also has a new ' D ' Shape connector on it ..
Unit 20
0151 3366888
Post by Shoppinit » Fri Oct 07, 2011 8:35 pm
There you have it then, you might as well gut your cats while you're at it :P
DRC
Post by DRC » Fri Oct 07, 2011 8:41 pm
I believe I've already got one.....
drybeer
Post by drybeer » Fri Oct 07, 2011 9:19 pm
Go on -
Change your nickname to "Torque converter reliability" just for a laugh!
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
DRC
Post by DRC » Mon Oct 24, 2011 9:05 pm
Well, got home, got a Vagcom, connected it up and voila:
1 Fault Found:
17090 - Transmission Range Sensor (F125): Implausible Signal
P0706 - 35-10 - - - Intermittent
Seems I need to replace the F125 with something that sends a more plausible signal.
...anyway, better than replacing the gearbox. :)
bilko1
Post by bilko1 » Tue Oct 25, 2011 12:20 am
Shoppinit wrote:Sounds more like a problem with the F125.
That boys good :jump_clap:
Users browsing this forum: No registered users and 251 guests
