Parking sensors
B3NEJ
Parking sensors
Post by B3NEJ » Mon Aug 22, 2011 9:17 am
Just wondered if anyone has had any issues with them? only had my car a week and they get a bit confussed sometimes. they have worked a few times but most of the times its give false measurements and even thinks i am about 2 inches away when really there is nothing at all around the car.
my car is under warrenty but just wondered if anyone has experianced issues like this and is there anything i can try (like a simple fix?)
many thanks
Ben
Audi RS4 2006
Past:
Audi A4 S-line 2009
Nissan Skyline 350GT (G35) 2003
Ford Focus ST 2006
Nissan 350Z 2003
Honda 2000 2003
rwilsonrs4
Re: Parking sensors
Post by rwilsonrs4 » Mon Aug 22, 2011 4:59 pm
Hi there i,m getting issues with the rears on mine it seems to be the rear right inner one giving false readings, the led comes on in the switch and it chimes constantly sometimes ,i havnt had the VCDS on yet tho , but when manually checking it its verry erratic on the right rear inner sensor , then sometimes its ok , i,m planning on getting it done under warranty when i get back home.
1/4 mile 12.01 secs 123.5mph
lma07
Parking sensors
Post by lma07 » Mon Aug 22, 2011 5:56 pm
Yip. Mine went wonky recently then self healed. Almors suggested pulling the fuse to see if it resets.
Ollieb7
Re: Parking sensors
Post by Ollieb7 » Mon Aug 22, 2011 7:49 pm
Funny, mine have just gone on the blink. Stick car in reverse and i get long constant beep and then they do feck all....
stu
Re: Parking sensors
Post by stu » Mon Aug 22, 2011 8:00 pm
My sensors see objects that aren't there on the first drive after a wash. Fixed instantly by getting out and wiping over each of the sensors when the parking assist is still on. Doesn't happen again.
B3NEJ
Re: Parking sensors
Post by B3NEJ » Mon Aug 22, 2011 8:29 pm
oh quite common then.... very odd, just went out and tested each one (a few times) and... they all work fine! you can even hear each one pulse when you put your ear to it.
does anyone know if pulling out the fuse helps? or is it just a bit of a red herring?
Audi RS4 2006
Past:
Audi A4 S-line 2009
Ford Focus ST 2006
Nissan 350Z 2003
Honda 2000 2003
Vlan_One
Re: Parking sensors
Post by Vlan_One » Tue Aug 23, 2011 11:58 pm
I have had a similar issue with my sensors in the front and I found that my reg plate came undone and was sitting about 1/2" forward. So the sensor right next to the plate was giving the alarm. Didn't know that they were that sensitive.
Daily: 08 Mk1 Caddy Sport
Toy: 07 Audi RS4 - "un-zorst-flapped"
Previous: 06 Mk5 GTI DSG .:. 96 Mk1 Caddy .:. 00 Mk4 GTI .:. 98 Mk3 GTI .:. 97 Mk1 Deco
almoRS
Re: Parking sensors
Post by almoRS » Wed Aug 24, 2011 5:11 pm
B3NEJ wrote:oh quite common then.... very odd, just went out and tested each one (a few times) and... they all work fine! you can even hear each one pulse when you put your ear to it.
Re-seating the fuses does work. Mine went a bit funny a couple of years ago and I reset the reversing lights and fuse for the sensors and all started working again.
RS3 Saloon, Merlin Purple, incoming.....
S3 Sportback Black Edition, Panther Black, BBS CHs
Previous:
RS6 C7 Riviera Blue, Carbon Pack, Sports exhaust, BC Forged HS04
C63 AMG Coupe, Fire Opal Red, Performance Pack, HRE P44SC's
RS4 B7 Saloon, Avus Silver, HRE P40s, Tubi exhaust
Volvo S60 R Black Saphire, Evolve Suspension + aerodynamics, BMC
Volvo S40 T4 Standard
lma07
Parking sensors
Post by lma07 » Wed Aug 24, 2011 6:26 pm
I remember reading Evo's long term test and they had the same experience with the number plate.
http://www.evo.co.uk/carreviews/evolong ... i_rs4.html
B3NEJ
Re: Parking sensors
Post by B3NEJ » Thu Aug 25, 2011 8:27 am
This morning i pulled out the No.17 fuse for a few mins and then re-seated, works perfectly now (fingers crossed).
many thanks, saves be a trip to the garage :beerchug: :beerchug:
Audi RS4 2006
Past:
Audi A4 S-line 2009
Ford Focus ST 2006
Nissan 350Z 2003
Honda 2000 2003
Stoffle32
Re: Parking sensors
Post by Stoffle32 » Thu Aug 25, 2011 8:47 am
It can also just be dirt or polish... I polished my car once and had left a very small white scuff from the polish on the once sensor, you had to look very closely to see if there was even a scuff... but I wiped it off and all was good again :-)
spikeyboy101
Re: Parking sensors
Post by spikeyboy101 » Thu Aug 25, 2011 1:38 pm
When i bought my RS4 last month found it had faulty parking senosers - had then checked and found the two passanger side sensors were faulty - having them replaced under warranty - not cheap.
£220 for the sensors - plus what ever it takes to fit them.
Seems strange that so many RS4 have the faults - had my S4 for over 5 years with no issues at all
rwilsonrs4
Re: Parking sensors
Post by rwilsonrs4 » Tue Aug 30, 2011 10:00 pm
ive just checked mine with VCDS and it came up code 01547 rear mid right sensor no signal comms , so i,ll have a look underneath tomorrow and see if a wires damaged or somethin, might save me driving 40 odd miles to get it checked by audi , then having to go back again to get it fitted because 1 they wont have one in stock and 2 it will need painted .
TAB1S
Re: Parking sensors
Post by TAB1S » Mon May 19, 2014 8:56 pm
Hi guys is there a way of resetting my sensors?
They worked fine until i ran my battery flat cleaning! Since then they dont make any sound?
Any help much appreciated.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift :mrgreen:
Stoffle32
Re: Parking sensors
Post by Stoffle32 » Tue May 20, 2014 7:15 am
plug your car into VCDS and see if there are any errors, otherwise your parking control module might be blown
Users browsing this forum: No registered users and 85 guests
