Hi all
Is it possible to turn off the tyre pressure sensors,i am about to change the alloys but want to keep the sensors
on my old wheels,or can new ones just be purchased.
If so how much are these ?
Tyre pressure sensors
Drive low,park lower
Re: Tyre pressure sensors
I think but not 100% that the TPMS can be disabled using Vag Com.
New ones aint cheap - IIRC they are about 70-100 quid a corner.
I am pretty sure you can but you may need to check insurance fine print incase you ever have an accident due to flat/low pressure tyre. They may not take kindly to a standard piece of equipment being turned off.Jules wrote:Hi all
Personnaly I am getting pretty close to putting my fist through the dash with the number of false warnings I get and how hopeless Audi are at fixing the problem....sorry
____________________
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Pug 405 NZ Touring Car
Toyota Landcruiser
C5 RS6 Avant
Gone
MRC'd B7 RS4
B6 3.0 A4
C5 A6
Toyota Landcruiser
I did it on mine using Vagcom using the process below. It basically removes it from the DIS menu altogether.
17 - Instruments - Adaptation - Channel 61. Subtract 512 from whatever value you find and save.
leont wrote:I did it on mine using VAGCOM using the process below. It basically removes it from the DIS menu altogether.
I'll give that a try
Many thanks
really? mine had been disabled by the previous owner (without telling me...bloody bastard) and only found out @ MRC,RSKiwi wrote: Personnaly I am getting pretty close to putting my fist through the dash with the number of false warnings I get and how hopeless Audi are at fixing the problem....sorry
and I really want to bring it in @ Camberley
"you can be my wingman anytime!"
"bullshit...you can be mine!"
CheeRS
CheeRS
Are you all now sorted then Fed?pisquano wrote:really? mine had been disabled by the previous owner (without telling me...bloody bastard) and only found out @ MRC,RSKiwi wrote: Personnaly I am getting pretty close to putting my fist through the dash with the number of false warnings I get and how hopeless Audi are at fixing the problem....sorry
Yep switch mine off after changing all the sensors and the aireal and stop got error signals the only other thing left to change is the control unit £400 form Audi so ill leave it for the moment
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Users browsing this forum: 22B and 146 guests
