Which engine oil is best?
Which engine oil is best, castrol edge, mobile 1 esp, millers, fuchs, and what about grades i know 5w 30 is recomended but has any one tried 10w 60 or any other grades
Hi check this out
http://forum.rs246.com/viewtopic.php?t=92301
Re: Which engine oil is best?
Why would you want to put in 10w60 unless you're doing some serious track/endurance work?
It will sap a fair bit of power and not give any useful advantage.
BMW use 10w60 in their m cars but the engine oil pathways are designed for the heavier oil.
To be honest, with modern oils grade is not as important as it once was. you can get a semi synth 10w40 and a fully synth 10w40 and they will perform completely different.
Titan fuchs pro s, silkolene are all good oils. Ideally a fully synth (a proper fully synth not a pretend one) ester based oil I find to be the best.
I went for Mobil 1 ESP Fully Synthetic w5 30 in the end
- PetrolDave
The grade is less important than ensuring it meets the required VAG spec as that covers grade, longevity, etc.
how much did you get it for and where did you buy it?HEo2TEC wrote:I went for Mobil 1 ESP Fully Synthetic w5 30 in the end
Looking in to the oil debate and found this info at opie oils
http://www.opieoils.co.uk/c-749-vw-50400-oil.aspx
hope it helps
Steve
hope it helps
Steve
Life is like petrol, the more you put in, the more you get out.
Fuchs or motul for me.
My 40k miles service is due this month, so looking at sourcing the oil myself to keep costs down.
- Steve_C
- Top Gear
That's what I did last week. Saved me £90!sonny wrote:My 40k miles service is due this month, so looking at sourcing the oil myself to keep costs down.
Gone to the dark side
Just as a heads up i can get the Castrol Edge 5w-30 Fully synthetic 4L for £28 if anyone is interested..
- Steve_C
- Top Gear
Good price. I paid £35 a couple of weeks ago.S14 wrote:Just as a heads up i can get the Castrol Edge 5w-30 Fully synthetic 4L for £28 if anyone is interested..
Bargain, pity I don't need any.S14 wrote:Just as a heads up i can get the Castrol Edge 5w-30 Fully synthetic 4L for £28 if anyone is interested..
Interested..S14 wrote:Just as a heads up i can get the Castrol Edge 5w-30 Fully synthetic 4L for £28 if anyone is interested..
Hi there Sonny i got it from camskill £38 for 5L it was the cheapest i could find, I've just done the oil change and took it for a spin it feels a lot smoother and it seams to have more of a kick at 5500 rpmsonny wrote:how much did you get it for and where did you buy it?HEo2TEC wrote:I went for Mobil 1 ESP Fully Synthetic w5 30 in the end
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 378 guests
