LED number plate bulbs
alex020869
Re: LED number plate bulbs
Post by alex020869 » Sat Jul 30, 2011 1:56 pm
Does anyone know what size of resistors these bulbs would need. Thinking i may just get the no-resistor LED's and fit resistors myself to save any hassle.
Alex
RS4 B7 Mugello Blue Saloon
PetrolDave
Post by PetrolDave » Sat Jul 30, 2011 6:10 pm
alex020869 wrote:Does anyone know what size of resistors these bulbs would need.
It's a simple Ohms Law calculation.
The LEDs take so little current you might as well assume they consume 1W.
So for a 21W bulb you need a resistor that will dissipate 20W, since R = V * V /P and V = 12V that means you need a resistor of about 144/20 Ohms i.e. 7 Ohms. The nearest standard value to that is 6.8 Ohms - so you want a 6.8 Ohm, 20W (or greater) resistor.
alex020869
Post by alex020869 » Sat Jul 30, 2011 7:50 pm
Thanks mate. Good thing to remember.
Alex
stuartbarriskell
Post by stuartbarriskell » Sun Jul 31, 2011 6:32 am
LOL, not been on for a few days, never realised this number plate thing was such a contentious issue... anyway, looks like we don,t have an easy solution, don't fancy this reisitor fitting scenario, think I will just live with the "yellowish" OE stuff....after all I rarely if ever see them..
Was a good chat for all anyway :=)
Current stable: B8 RS4.
13 BMW HP4 Track/Road
21 BMW S1000RR Sold
04 ZX 10R Sold
MV Agusta Reparto Corse Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
scaghead
Post by scaghead » Sun Jul 31, 2011 6:37 am
stuartbarriskell wrote:LOL, not been on for a few days, never realised this number plate thing was such a contentious issue... anyway, looks like we don,t have an easy solution, don't fancy this reisitor fitting scenario, think I will just live with the "yellowish" OE stuff....after all I rarely if ever see them..
you get back on the whisky fella...
ArthurPE
Post by ArthurPE » Sun Jul 31, 2011 3:50 pm
a couple of questions:
wattage of oem bulbs
are they in series? unlikely, if one bulb is pulled do both go out?
parallel?
or seperate circuits for each (supply/sensing per bulb from the controller)?
anyone have a wiring schematic for reference?
if in parallel one resistor would do it...
some good info http://nickscarblog.com/diy/led-license ... 005-5-2008
this link would indicate in parallel, ie, one balancing resistor http://www.audizine.com/forum/showthrea ... late-light!!
PetrolDave
Post by PetrolDave » Sun Jul 31, 2011 4:25 pm
ArthurPE wrote:a couple of questions:
parallel?
According to the wiring diagrams I've seen they are separate circuits.
Stoffle32
Post by Stoffle32 » Tue Aug 02, 2011 8:32 am
hey all
Sorry for the late reply, seems these Rs4's are very temperamental...
So on the weekend took the Rs4 out, and I got a warning when started the car said the number plate light was out, got out the car to check was all working fine...
The warning however did not stay like it usually does it just flashed once then went away, and if you push the check button it does not come back...
What is strange though is, I dont leave my car parked in Auto for the lights, unless im going out that night etc... If you leave it on auto the error does not come up at all :?: :?:
So this is confusing me a lot, however reason why I have not posted the link is because i want to speak to were it comes from to find out exactly what is happening before a bunch of you go out and purchase them and they give you an error...
scaghead
Post by scaghead » Thu Aug 04, 2011 7:16 am
stoffle i know what you mean fella, one of the sets i brought worked fine for a day or so then chucked up a fault code intermitently... :bash: good luck fella hope you get it sorted
lma07
Post by lma07 » Thu Aug 04, 2011 8:33 am
I get the same error periodically on my led rear lights. Right fog light. It is working but sometimes get the dash warning light appear
If I switch off auto lights it's happy but I prefer to keep auto lights on (it's too much effort to switch on my lights manually) :-)
I spoke to Danny at the national gathering and he said there is a code on Vagcom that you can use to correct it.
Vlan_One
Post by Vlan_One » Thu Aug 04, 2011 10:51 pm
Stoffle32 wrote:hey all
I picked up the same set as yours from the same supplier yesterday, put them in this morning and worked without any error. During the day I got in the car pressed the start button and found the same problem. I got the quick message about the number plate lights and it also went away immediately and pressing the check light revealed nothing. I then tried switching off the car even took out the key and on every start after that, no error. I always leave the lights in auto and have coming home enabled. Seems to be only on the first start after thew car stood for a while.... hope it helps to establish a pattern.
Have you spoken to the supplier yet?
Daily: 08 Mk1 Caddy Sport
Toy: 07 Audi RS4 - "un-zorst-flapped"
Previous: 06 Mk5 GTI DSG .:. 96 Mk1 Caddy .:. 00 Mk4 GTI .:. 98 Mk3 GTI .:. 97 Mk1 Deco
DazN
Post by DazN » Fri Aug 05, 2011 8:50 am
Does anybody know if I went down the route of LED lights without built in resistors do I then have to add 1 resistor per light or just 1 resistor on the 'loom'?
Reason for asking is I have just fitted a rear view camera and that has an LED bulb in, which is now giving me this error, so I want to change the opposite light and then add resistor(s).
I have noticed a few places on eBay that sell a pair with built in resistors for <£30, I could buy a pair and just fit 1?
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
DazN
Post by DazN » Fri Aug 05, 2011 8:55 am
Audi S4 (B9)
Gone:
C63 Coupe (2014)
Audi S4 (B8)
BMW M3 (E90)
Audi RS4 (B7)
BMW M5 (E60)
BMW M3 (E46)
mikeypur
Post by mikeypur » Fri Aug 05, 2011 12:43 pm
would these do the trick?
http://www.ecstuning.com/Audi-B7_RS4--V ... ES1899488/
or would you need a resitor fitted along with these?
B7 RS4 Daytona Grey Avant
MB2
Post by MB2 » Fri Aug 05, 2011 2:25 pm
Those are the "racing dash" ones, & didn't work with my car (triggered errors & flickered) although work or not seems a bit variable car by car.
Users browsing this forum: dan32v and 103 guests
