HELP -Traction control and epc light limp mode
Jonesy07
Post by Jonesy07 » Thu Aug 04, 2011 7:33 am
Just on my way into work and these two lights came on and put the car in limp mode.
Pulled over and stopped the car, on restart they went off. Got just down the road to work and they have come on again. Called audi assist and they are coming out.
Anyone got any ideas on what may be the problem ?
Current : S3 8p while on the RS3 hunt.
Previuos : B7 RS4 Avus Avant | RS4 Sal | R32 | Cayenne | Z4M | R32
pekingprawn
Re: HELP -Traction control and epc light limp mode
Post by pekingprawn » Thu Aug 04, 2011 7:57 am
My friends car did this last week, be interesting to know what the outcome is, good luck with it though.
neckarsulm
Post by neckarsulm » Thu Aug 04, 2011 9:01 am
vacuum leak, prob from area behind offside headlamp
pekingprawn
Post by pekingprawn » Thu Aug 04, 2011 9:04 am
Can you add more detail to that? Leak from what system?
adsgreen
Post by adsgreen » Thu Aug 04, 2011 9:45 am
I dunno - normally I'd agree with vacuum leak but the traction control light is interesting.
perhaps a wheel speed sensor is screwing things up?
Vagcom needed to see the logs - you may also get a generic odb code from a normal odb reader which might help.
How was the car running with the lights on? misfire? rough running? problem idling?
2manytoys
Post by 2manytoys » Thu Aug 04, 2011 9:51 am
MAF Failure
adsgreen
Post by adsgreen » Thu Aug 04, 2011 9:56 am
But why the traction control light? Thats the bit thats screwy to me.
Are you sure it was the traction control light and not the engine malfunction light?
2manytoys
Post by 2manytoys » Thu Aug 04, 2011 10:31 am
Traction Control relies on the MAF also.
Jonesy07
Post by Jonesy07 » Thu Aug 04, 2011 10:54 am
adsgreen wrote:But why the traction control light? Thats the bit thats screwy to me.
yes come up with the traction light.
Fault is showing throttle pedal position sensor/ switch. Got to back to the dealer as not a road side fix.
Nice couple of hours in the rain ! :audibash:
Jonesy07
Post by Jonesy07 » Thu Aug 04, 2011 2:49 pm
Well its back at Audi for them to look at.
Audi assist just delivered my hire car and its a brand new (30 miles on the clock) A4 170ps Black edition avant !
Was not expecting that so thank you Mr Audi :beerchug:
stevomepy
Post by stevomepy » Thu Aug 04, 2011 3:00 pm
My RS4 did this - - I reckon its one of your engine "brains" - the RS4 B7 has 2 ECU`s - one of mine went kaputt and gave me this same symptom
pekingprawn
Post by pekingprawn » Thu Aug 04, 2011 3:20 pm
Keep us posted on the outcome, could be any number of things really.
thedoluk
Post by thedoluk » Thu Aug 04, 2011 10:37 pm
Mine did this today also. Checked the code and it's throttle pedal position sensor. £57 from TPS.
Daytona Avant - Optics - Titanium pack - MRC 464.6ps 513Nm - H&R ARBs + Springs - Apikol Diff mount - 034 Tranny mount - JHM Shifter
Post by Shoppinit » Fri Aug 05, 2011 6:27 am
2manytoys wrote:MAF Failure
^^ that is what I would have said. Mine has done this too when the MAFs weren't seated properly. Good to know you found the problem though.
I would be interested to know what the link is with the MAFs and ABS / ESP.
adsgreen
Post by adsgreen » Fri Aug 05, 2011 6:39 am
I would imagine that it uses the NSF to gauge how much to cut the throttle when the ESP kicks in to limit wheelspin.
More accurate than just measuring throttle position and guessing how much air should be moving.
