what to do....
2.7 V6 30v biturbo - 380 bhp
Nasty
what to do....
Post by Nasty » Tue Jul 19, 2011 10:33 pm
hi , i hope someone can help me to find out whats wrong .
when im getting past 4000 rpm , its like hes holding down the power . like he hesitate .
now my thought was , that it can be the lambda probe . can it be or something else is going out? (hope not)
anyone know the right values for the lambda?
thanks
kiwi_rs4
Re: what to do....
Post by kiwi_rs4 » Thu Jul 21, 2011 1:35 am
Could be a number of things, but faulty MAF or EGT(s) are a common cause of power loss. Could also be a boost leak or broken DV I suppose.
Nasty
Re: what to do....
Post by Nasty » Thu Jul 21, 2011 12:43 pm
hi , like u said , it could be many things .
they told me @ audi , it could be the sparkplugs :roll: but i have my doubts about that.
well monday i should get new ones and will see what it does. otherwise the search continues :x
grtz
RS2_Russ
Re: what to do....
Post by RS2_Russ » Sun Jul 24, 2011 1:12 pm
As Kiwi says, could be so many things: air bleeds, DVs, MAF, who knows.
Save your money just replacing things (especially at Audi stealer prices) and take it to a specialist (Unit 20/MRC,etc) - soon.
01 Goodwood Green RS4. Stage II MRC (460BHP/480lbft).
Audi S8 5.2 V10 Daytona Grey, RS4-type alloys, B&O sound [Gone]
95 Ragussa Green RS2, unmodified and great [Gone]
Nasty
Re: what to do....
Post by Nasty » Sun Jul 24, 2011 9:12 pm
well tomorrow we gonna look further into it. starting with sparkplugs :roll: then fuelpump . those 2 things can do the trick they say :shock:
when they scanned the car, there where no faults found on the MAF. thought it was the lambdaprobes , but there good.
just got 2 faultcodes from engine bank one to rich , and engine bank 2 to poor.
hope we find it , otherwise gonna see here in belgium for a specialist .
ill keep it posted :wink:
grtz
Nasty
Re: what to do....
Post by Nasty » Mon Jul 25, 2011 8:19 pm
well , the sparkplugs was a big help i must say, new airfilter, and i ordered a new MAF to .
powerloss is gone :) that was a relief.
grtz
Nasty
Re: what to do....
Post by Nasty » Fri Aug 12, 2011 8:40 pm
hi ,
well i need some advice about the clutch. he gave up on me today :rant:
what to do ... a new one from audi or a stronger one from ....
all the advice is welcome .
grtz
thank u in advance
Re: what to do....
Post by Ian_C » Fri Aug 12, 2011 8:56 pm
Yikes. Would personally go with original Audi parts for the clutch and flywheel unless you are running big tuned power and torque. However I'd be looking at a respected indy like APS, MRC, QST, Unit 20, Russell Automotive, Fontain etc rather than paying Audi £100 + vat per hour for the 6 / 8 hours or whatever the book time is on the B5. Not sure what flywheel the B5 RS4 runs, nor whether you have to replace the flywheel everytime you replace the clutch like you have to on the B6 B7 V8s.
Nasty
Re: what to do....
Post by Nasty » Fri Aug 12, 2011 10:35 pm
hi ,
well the car is standard . so maybe is a oem clutch the best then?
don't think the flywheel is gone , cause it shifts good and so on . but if i go full throttle the rpm goes up like hell and the car isn't moving like it should be :roll:
and it smells burnt so not a good sign.
grtz
Re: what to do....
Post by Ian_C » Fri Aug 12, 2011 11:01 pm
On the V8s the flywheel has to be done in tandem with the clutch. I'm sure a B5 owner will be able to confirm whether this is the case on the V6.
graemep
Re: what to do....
Post by graemep » Sun Aug 14, 2011 9:45 pm
Clutch is typically 6hrs labour, plus the cost of the parts. The only reason I did mine at 86k was due to the fact the 'box had to come off to get the 1st and 2nd synchros done, so made sense to replace it at the same time.
Flywheel doesn't have to be done at the same time if the current one is OK.
Nasty
Re: what to do....
Post by Nasty » Sun Aug 14, 2011 10:48 pm
ok thanks for clearing that up. original it is a sachs right so gonna go for this one then.
hope its gonna be fixed soon , miss it already :roll:
grtz
Nasty
Re: what to do....
Post by Nasty » Wed Aug 31, 2011 10:10 pm
hi
does the new clutch have a break in period? some say it does , some say no.
http://en.sachsperformance.com/sachs-ra ... set-2.html
this is the clutch in Question.
grtz
Users browsing this forum: Google [Bot] and 61 guests
