RS4 PARTS CLEAROUT..
- 5th Gear
ive got too much stuff in the garage so here goes.
s4 engine , complete apart from egt sensors,turbos and tbb. 90k £550
ko4 turbos £600
k04 intake pipes, set of 4 . £175
2.8 n/a inlet cams £50
set of rs4 cams inlets done 110k exhaust out of 2.8 heads so had an easy life £150
rs4 heads, bare castings with valves and springs , no cracks, cleaned and skimmed . £800
avus rs4 £10,000
fdp rs4 gearbox £750
rs4 wheels , round but powder coating flaking£80 each
1 refurbed rs4 wheel.good as new £150
rs4 engine loom, £40
rs4 black leather door cards. £60
mtm v2 cearmic coated rs4 exhaust manifolds £1200
st2 rs6 turbos with mrc intake pipes, refurbed and as new £3300
2.4 heads ported and polished by jnl racing complete with supertech springs and titanium retainers, cams, followers covers etc. heads done 5k ,valve train done 23k £2500
rs4 bottom end , overhauled 5k ago with mrc rods , rehoned bores , new piston rings, new big ends. £1800
prices plus delivery.
ko4 turbos £600
avus rs4 £10,000
665 bhp + 586 lbft...
Re: RS4 PARTS CLEAROUT..
Jimbo do you still have the door cards
I'm looking for the grab handle shells (if in good nick) to replace mine
Graze
Graze
Current
V12 Vantage S
Sold
2007 B7 RS4, Ibis white, 8mm spacers, carbon chin spoiler
2001 B5 RS4, Metallic Black, Neuspeed rear ARB, 275/30/19's + 10mm spacers on B7 RS4 wheels! 034 motor mounts, APR snub mount, JHM shortshifter, 18Z calipers & slotted rotors, custom FBSW
V12 Vantage S
Sold
- 5th Gear
hi , all my parts are b5 rs4 , you have a b7 dont you ? jim
Hey, do you still have the turbo's?
- mikeyquattro
- Top Gear
Graze has a B5 too....jimbo1234567 wrote:hi , all my parts are b5 rs4 , you have a b7 dont you ? jim
Tomorrow is another day
- 5th Gear
this original ad is ancient, heres my current list of parts for sale.
propshaft £50
engine loom £150
gear linkage £40
front drive shafts with cv joints £50each
rear drive shafts £50 each
air con rad £30
fan control module £30
wiper arms and blades £10
a/c pipes on engine £35
boot floor securing net £30
mint silver leather interior inc door cards £900
glove box £10
rs4 carbon engine covers £235
oem catback exhaust system £60
full set of shell panels with bumpers and arch liners £2500
front discs calipers ,carriers ,hosesand pads ,mint cond discs £350
load cover £35
cargo net £20
90k rs4 engine longblock with fsh £2000
steering wheel with airbag £100
Wiper linkage and motor £50
Central locking pump £30
Seatbelts set of 4 £80
Pas resevior cover £5
Set of matts, not brilliant £15
Oem rear diff mount £5
Driveshaft heat shields , the pair £20
A/c condensor £15
Horns the pair £10
Rear arb drop links £20
Metal rs4 throttle body boot £75
Aux fan front £20
Aux fan rear £20
Brake servo £20
Brake master cylinder £15
Brake fluid resevior £10
Pedal box £40
Rear top arms £30
Fuel lines( engine bay) £10
Bonnet strut £20
Abs module £150
Oem duall mass flywheel , top notch £50
Airbag module £125
Alloy roof rails £50
Rear lights pair £40
Front abs sensors each £30
Top lambda sensor £20
Lower lambda £20
Clutch slave cylinder £15
4 shocks and springs, rears nearly new £100
6 month old rear shock top mounts £80
rs4 injectors £70
fuel tank complete with pump £150
leather wallet, binder and all books £30
lock set with keys £80
wheel well insert complete £30
bonnet (goodwood) £80
good battery £25
propshaft £50
engine loom £150
gear linkage £40
air con rad £30
glove box £10
load cover £35
cargo net £20
A/c condensor £15
Horns the pair £10
Aux fan front £20
Aux fan rear £20
Brake servo £20
Pedal box £40
Rear top arms £30
Bonnet strut £20
Abs module £150
Airbag module £125
Lower lambda £20
rs4 injectors £70
good battery £25
Hi
Have you still go the fuel pump?
Thanks in advance
Fred
Thanks in advance
Fred
Hallo, front brake kit is original b5 or B7 rs4?
METALLO VELOCE
RS2 I5 B4 2,2 20v turbo avant 315HP
RS4 V6 B5 2,7 30v biturbo 380HP
Hello, looking for metal throttle body boot and bi pipes that connect to boot.rs 4 b5
Thank you
Serge
V_kgb_way@hotmail.com
Thank you
Serge
Hi do you still have the RS4 bottom end thanks
- 5th Gear
wow this thread is 3 years old. I have been breaking b5 rs4,s for 2 years now so a lot of parts have come and gone.i have a lot of stock so let me know what you need.
I know this thread is old but do you have an RS4 glovebox? Thanks
Isn't it the same as a normal A4? Thought there'd be loads on ebay.divine wrote:I know this thread is old but do you have an RS4 glovebox? Thanks
It probably is tbf. I will find out. ThanksMikeFish wrote:Isn't it the same as a normal A4? Thought there'd be loads on ebay.divine wrote:I know this thread is old but do you have an RS4 glovebox? Thanks
- 5th Gear
yes ive a good one here £35 delivered, the shade of the black plastic can vary and be a blueish colour if a non rs4 part.
Users browsing this forum: Google [Bot] and 32 guests
