Rs6 cam locking tool needed help !!!!
Hi all after taking my rs6 on 1000 mile road trip my water pump is not happy, and I have to replace it along with the cambelt !! Has Any one got a cam locking tool ?????????? I could borrow or rent, I live in Birmingham and can collect it. I would be most grateful if I could borrow or rent the tool for a couple of days.
Re: Rs6 cam locking tool needed help !!!!
You'll need the crankshaft locking tool, too.
http://www.sealey.co.uk/PLPageBuilder.a ... results=16
Don't forget to replace your tensioners and thermostat, too.
Plenty on ebay.de too. If you ask nicely they'll generally devilver to the UK.
http://shop.ebay.de/i.html?_from=R40&_t ... Categories
That's brill thanks will do, yer I looked on eBay and they have them to rent it's just they want £130 deposit first along with the rental it's not a problem but would rather give someone on here the money to rent one.
Looks like a fairly straightforward job. I would definitely do this myself if it wasn't for wanted to keep FASH.
Yer it looks nice to do once the front end is out the way, also what spark plugs do you reccomend ????
NGK PFR7Q definitely.
- 1st Gear
Is there a good guide to doing the cam belt, fancy having a go when it's due early next year ?
RS4 B7
78 911
7 BEC R1
Gone but not forgotten
Elise, 964 C4, BMW 330, RS6 ,WRX x 2, Sti x 2, RS4...
78 911
7 BEC R1
Toy boy!
How is your RS6? Not the best!
Havnt seen you in ages bigman
Hmm ok, just want to know how would you get the 3 radiators and 1 other cooling thingy out of the way, without disassembling them?Shoppinit wrote:Looks like a fairly straightforward job. I would definitely do this myself if it wasn't for wanted to keep FASH.
I started the job to replace my thermostat, but as far as I saw I did not have any room to move all the radiators out of the way.
According to ELSA you have to get complete front out of the way and as far as I saw that would mean draining the engine coolant, oil, ATF, the AC...
Not something I have done before and surely also refilling them (ATF and AC) is something I do not want and perhaps even can do.
So tips and trics to remove the front, or even just move the front perhaps a decent 10-20cm without having to drain any fluids would make a big difference.
STOLEN : Das phantom: Ebony Black, RS6+ optic package in- and outside, some sort of ECU remap, sportec exhaust, 275/30 19 with RS6+ rims. --> "GTA is da new name of da game. "
Haven't seen that writeup before - thanks Shoppinit. Any thoughts from folk on here on using waterpump gasket sealant? Have always steered clear when I've done this job on other Audis (not tried it on the RS6) but assuming you can clean it up without any trouble I can't really see the disadvantage.
RS6 Avant (C5), Daytona grey
Gone but not forgotten: S4 Avant (B5)
hmm, wished I've seen that post sooner.
Í'll save the link and use it next time
tnx.
tnx.
Users browsing this forum: No registered users and 55 guests
