RNSE
johnny11
RNSE
Post by johnny11 » Wed Jul 06, 2011 10:33 pm
I had the alternator on my 2003 done last week, but today i went to use the sat nav and the location was not updating fast enough for it to work, so i checked the signal in the engineering mode and all fine seeing lots of satellites and seeiing my mph on the Gps, then i checked the speed pulse and this wasn`t working at all, not seeing my speed or anything. So my question is does, anyone know where this gets the speed pulse from? and any ideas what the garage could of knocked or done for this not to work?
Re: RNSE
Post by Shoppinit » Thu Jul 07, 2011 11:53 am
Was it upgraded from RNS-D?
Re: RNSE
Post by Shoppinit » Thu Jul 07, 2011 12:25 pm
The speed signal comes from the dash, so if your speedo's working then I'm confused about why your nav isn't getting the signal. Perhaps trace the wire?
johnny11
Re: RNSE
Post by johnny11 » Thu Jul 07, 2011 3:01 pm
Yep was upgraded from RSND in Feb 2007 by Craig B and has worked fine until last week when i got back from having a new alternator fitted. Everything on the dash works speedo etc. I`m just really confused as everything else on the unit it working fine, its as if the speed pulse is turned off, is there anyway to turn this on or off?
Re: RNSE
Post by Shoppinit » Thu Jul 07, 2011 3:11 pm
Not unless you put a switch between the dash and the RNS-D which is what I did.
Re: RNSE
Post by Shoppinit » Thu Jul 07, 2011 3:12 pm
I'm assuming you took the GALA from the original RNS-D harness.
MoRS6+
Re: RNSE
Post by MoRS6+ » Thu Jul 07, 2011 3:35 pm
johnny11 wrote:Yep was upgraded from RSND in Feb 2007 by Craig B and has worked fine until last week when i got back from having a new alternator fitted. Everything on the dash works speedo etc. I`m just really confused as everything else on the unit it working fine, its as if the speed pulse is turned off, is there anyway to turn this on or off?
I'd try to get hold of craigyb himself in that case. I'm sure he wouldn't mind spending 2 minutes letting you know what it could be. Would probably tell you what to look for straight away. Maybe something got reset/lost when it lost power? Worse case, something got sliced or snagged.
johnny11
Re: RNSE
Post by johnny11 » Sat Jul 09, 2011 2:41 pm
When i look in engineering mode, on the nav sensor info there seems vehicle signal says its off, is it possible that if anyone can look at there rnse in engineering mode and see if thats the same on theirs.
thanks
heres how mine looks at the mo,
Re: RNSE
Post by Shoppinit » Sat Jul 09, 2011 2:51 pm
You are telling everyone where you car is located at the moment ;)
Re: RNSE
Post by Shoppinit » Sat Jul 09, 2011 2:53 pm
Also, I'm no expert but I would presume that the "OFF" on the screen is refering to the revserse switch signal, not speed.
johnny11
Re: RNSE
Post by johnny11 » Sat Jul 09, 2011 3:05 pm
Shoppinit wrote:You are telling everyone where you car is located at the moment ;)
opps ta :bash:
Re: RNSE
Post by Shoppinit » Sat Jul 09, 2011 4:20 pm
When you drive the car with the engineering screen up what happens to the pulse count and speed numbers?
johnny11
Re: RNSE
Post by johnny11 » Sat Jul 09, 2011 4:54 pm
Nothing, stays the same.
Re: RNSE
Post by Shoppinit » Sat Jul 09, 2011 5:11 pm
Does sound like the signal's not getting from the dashpod to the head unit. Bit of a mystery as to why that would be though. Perhaps pull the head unit out and see if there's an obvious problem with the gala wire?
johnny11
Re: RNSE
Post by johnny11 » Sat Jul 09, 2011 7:50 pm
All done and working, i removed the unit gently, then i noticed 1 wire on the back that was hanging there all on its own which which had the metal connector on the end and had come out of the connecting block that plugs into the unit. On top of the unit it tells you what pin connector should connect to, and the no.3 pin was the vehicle signal and this had the wire missing, so pushed the lonely wire in the connector block, connected that to the unit, had a drive round and its all come back to life. so you were spot on Shoppinit. The only thing that i don`t understand is how this come out, but who cares its all working now.
Thanks again
Users browsing this forum: Majestic-12 [Bot] and 276 guests
