This service is going to have to be done on my car after I got an ATF leak from pipe 4B3317817E
More corrosion! and just after I got her all patched up after her coolant leak
Did you read this article ?Shoppinit wrote:Might help if I post the right link:
http://www.audipages.com/Tech_Articles/ ... icing.html
http://forum.rs246.com/viewtopic.php?f= ... 7&p=444438&Shoppinit wrote:Peugeot or Citroen will probably be the cheapest. It's all the same stuff.
You need:
5 - Gasket - 01L 321 371
8 - Plug and seal - 01L 321 371
10 - O ring - 01V 321 379
28 - Strainer - 01L 325 429B
29 - Gasket - 01L 325 443
Don't think anything else is necessary.
PPP>MECHANICALS / MAINTENANCE>OILS
OIL FOR AUTOMATIC GEARBOX AND POWER STEERING ATF 4HP20/AL4 (1L)
Fam. N° 908
9730 AE
ATF 4HP20/AL4 (1L)
ESSO
1 x 12
Not marketed in country
• Photo not contractually binding
• NON-CONTRACTUAL PHOTO.
________________________________________
Description
• Esso 4HP20/AL4 oil specifically for automatic gearboxes 4HP20/AL4
• 1 litre container
Sales statements
• Automotive repair professionals.
• Oils approved and recommended exclusively for CITROËN and PEUGEOT vehicles
• These oils are identical to the oils used on the assembly line and possess the same physical and chemical characteristics and properties.
• Special oil for topping up automatic gearboxes and power steering (except electric)
Users browsing this forum: No registered users and 326 guests
