HEEEEEELP! DISASTER STRIKES
My 06 plate 52k saloon was serviced last week, and on Friday at startup sounded TERRIBLE with a chattering from the NS cylinder head. Today's diagnosis is a timing chain problem, or failed tensionner. The cure (hopefully) is to take the engine out, (25+ hours at Audi rates @£95 + VAT) to replace all 3 chains estimated £3500. Is there anyone who knows of and can recommend and independent in the South Yorkshire who are up to the job at hopefully a lower hourly rate?
Re: HEEEEEELP! DISASTER STRIKES
Unit 20 or MRC I think will be your best bet.
- Steve_C
- Top Gear
+1, Unit 20 probably close to you (Cheshire), MRC are in Banbury.sonny wrote:Unit 20 or MRC I think will be your best bet.
Gone to the dark side
How long since you had a full oil change?simonp wrote:My 06 plate 52k saloon was serviced last week, and on Friday at startup sounded TERRIBLE with a chattering from the NS cylinder head. Today's diagnosis is a timing chain problem, or failed tensionner. The cure (hopefully) is to take the engine out, (25+ hours at Audi rates @£95 + VAT) to replace all 3 chains estimated £3500. Is there anyone who knows of and can recommend and independent in the South Yorkshire who are up to the job at hopefully a lower hourly rate?
Does the noice disapear after a couple of seconds?
Is it only happening when the engine's cold?
The reason I ask is that I had been experiencing the same thing occasionally.
Mentioned to Doug @ MRC last week and again he inferred it may be the chains/tensioners.... HOWEVER, if your running old and therefore THIN oil, overnight it will naturally run away from the tensioners etc and thus leave them DRY when you come to start again in the morning.
Gave it an oil change there and then. Touch wood, the clatter hasn't returned.
Just a thought.
JUST been serviced (i.e. 30 miles ago) at a main dealer so I hope brand new oil-it's not just a noise, its easily audible from the drivers seat, and the valve timing is erratic hence diagnosis of a floppy chain
Oh well, shame man.
So has this only occurred since it was serviced ???
they did put enough oil in?
there was no oil level warning over the 50 miles covered since the service-it's probably bad luck - I can't believe a straightforward service could bu88er the chain
The joys of running a performance saloon car
Mint Optic Pack saloon in Daytona Grey (Now sold)
B7 RS4 in Sprint Blue (Gone to a very good new home)
Evo V1 (wish i'd kept)
Numerous M3s
Numerous M3s
Gives you the shivers that! Hope you get it done for a reasonable price. Will they not offer some goodwill on the job seeing as they just did a service? If you don't ask (twice), you don't get..
RS4 B7 06 Daytona Saloon
too much of a coincidence IMHO
Not sure if this is an engineering thing or an Audi thing but when my motor was out for the valve clean the dealer 'recommended' that I have the tensioners replaced at the same time. Mine had done 44k at the time, I know you'd replace certain stuff as a matter of course, I had a new clutch put in but tensioners??
Users browsing this forum: Google Adsense [Bot] and 101 guests
