HEEEEEELP! DISASTER STRIKES
simonp
Post by simonp » Tue Jun 14, 2011 7:48 pm
My 06 plate 52k saloon was serviced last week, and on Friday at startup sounded TERRIBLE with a chattering from the NS cylinder head. Today's diagnosis is a timing chain problem, or failed tensionner. The cure (hopefully) is to take the engine out, (25+ hours at Audi rates @£95 + VAT) to replace all 3 chains estimated £3500. Is there anyone who knows of and can recommend and independent in the South Yorkshire who are up to the job at hopefully a lower hourly rate?
sonny
Re: HEEEEEELP! DISASTER STRIKES
Post by sonny » Tue Jun 14, 2011 8:10 pm
Unit 20 or MRC I think will be your best bet.
Steve_C
Post by Steve_C » Tue Jun 14, 2011 8:19 pm
sonny wrote:Unit 20 or MRC I think will be your best bet.
+1, Unit 20 probably close to you (Cheshire), MRC are in Banbury.
Gone to the dark side
Timster
Post by Timster » Tue Jun 14, 2011 9:00 pm
simonp wrote:My 06 plate 52k saloon was serviced last week, and on Friday at startup sounded TERRIBLE with a chattering from the NS cylinder head. Today's diagnosis is a timing chain problem, or failed tensionner. The cure (hopefully) is to take the engine out, (25+ hours at Audi rates @£95 + VAT) to replace all 3 chains estimated £3500. Is there anyone who knows of and can recommend and independent in the South Yorkshire who are up to the job at hopefully a lower hourly rate?
How long since you had a full oil change?
Does the noice disapear after a couple of seconds?
Is it only happening when the engine's cold?
The reason I ask is that I had been experiencing the same thing occasionally.
Mentioned to Doug @ MRC last week and again he inferred it may be the chains/tensioners.... HOWEVER, if your running old and therefore THIN oil, overnight it will naturally run away from the tensioners etc and thus leave them DRY when you come to start again in the morning.
Gave it an oil change there and then. Touch wood, the clatter hasn't returned.
Just a thought.
simonp
Post by simonp » Tue Jun 14, 2011 9:08 pm
JUST been serviced (i.e. 30 miles ago) at a main dealer so I hope brand new oil-it's not just a noise, its easily audible from the drivers seat, and the valve timing is erratic hence diagnosis of a floppy chain
Timster
Post by Timster » Tue Jun 14, 2011 9:11 pm
Oh well, shame man.
So has this only occurred since it was serviced ???
adsgreen
Post by adsgreen » Tue Jun 14, 2011 10:13 pm
they did put enough oil in?
simonp
Post by simonp » Tue Jun 14, 2011 11:04 pm
there was no oil level warning over the 50 miles covered since the service-it's probably bad luck - I can't believe a straightforward service could bu88er the chain
victor2vt
Post by victor2vt » Wed Jun 15, 2011 12:01 am
The joys of running a performance saloon car :kissmyrings:
Mint Optic Pack saloon in Daytona Grey (Now sold)
B7 RS4 in Sprint Blue (Gone to a very good new home)
Evo V1 (wish i'd kept)
Numerous M3s
rs4007
Post by rs4007 » Thu Jun 16, 2011 12:49 pm
Gives you the shivers that! Hope you get it done for a reasonable price. Will they not offer some goodwill on the job seeing as they just did a service? If you don't ask (twice), you don't get..
RS4 B7 06 Daytona Saloon
neckarsulm
Post by neckarsulm » Fri Jun 17, 2011 10:39 pm
too much of a coincidence IMHO
pad125
Post by pad125 » Sat Jun 18, 2011 3:11 pm
Not sure if this is an engineering thing or an Audi thing but when my motor was out for the valve clean the dealer 'recommended' that I have the tensioners replaced at the same time. Mine had done 44k at the time, I know you'd replace certain stuff as a matter of course, I had a new clutch put in but tensioners??
