Emissions light - Help please..
GaryCollinson
Post by GaryCollinson » Tue May 10, 2011 8:14 am
Hi all,
Having had my RS6 C5 for approximately 1 week I noticed the emissions lamp suddenly became lit. At first I thought it may have been because the petrol pump guy had put 95 RON petrol in. I waited until the tank was fairly empty and made sure it was filled up with Super. I borrowed a mates Elm 327 OBD code reader and reset the light.
However, after another few days the lamp again came on. This time I analysed the codes and took the attached screen shot.
Can anyone assist with likely causes of the reported problems?
I was tempted to take it to Audi here in the middle east but want to avoid the "lets change and charge you for 10 parts" situation when I had a similar problem with my Carrera 4.
Any assistance greatly appreciated.
Gary
Diagnostic Result
Re: Emissions light - Help please..
Post by Shoppinit » Tue May 10, 2011 10:45 am
I'm betting MAFs not seated correctly. Possibly a deteriorated o-ring given where you are.
Or simply bad MAFs.
Could be bad lambda sensors but more likely the MAFs.
Can your obd2 reader do live readings? If so see what g/s the MAFs are reading.
delboymafia
Post by delboymafia » Thu May 12, 2011 9:03 am
Ho there, i had a similar problem, it was down to me not using the car enough and the MAFs weren't working properly. My garage cleaned the MAFs and touch wood, all is ok. Hope this helps. Chris.
GaryCollinson
Post by GaryCollinson » Thu May 12, 2011 2:26 pm
Shop, Chris
Thanks very much for your replies, it certainly gives me something to work with. I'll get some accurate readings off the MAFs and at least this will hopefully narrow down the problem.
If there was issues with hoses would this show when you check the MAF readings? (sorry all a bit new to this technical stuff..)
Post by Shoppinit » Thu May 12, 2011 2:41 pm
Yup, could be a vacuum leak somewhere else, too. Check all the little vacuum hoses running all over the inlet manifold. You'll have to remove the airbox to see them all.
This might be the source of your problems, actually.
posterboyj
Post by posterboyj » Thu May 12, 2011 8:50 pm
Possible Causes
Mass Air Flow Sensor (G70) defective Intake System Leak(s)
Possible Solutions
Check Mass Air Flow Sensor (G70) Check Fuel Pressure Regulation Check Fuel Pump Check Injectors Check Intake System for Leaks Check Exhaust System for Leaks Check Secondary Air System for Leaks Check Vacuum Pipes for Leaks
Possible Causes
Fuel system Excessive fuel pressure Leaking or contaminated fuel injectors Leaking fuel pressure regulator Low fuel pressure or running out of fuel Vapor recovery system Air leaks after the MAF Vacuum leaks Improper seated engine oil dipstick Stuck EGR valve Oil overfill Cam timing Cylinder compression Exhaust leaks before or near HO2Ss.
Cornishmoocher wrote:Buying an RS6 and then worrying about the fuel consumption is a bit like buying a boat and worrying about getting it wet.
el_ringo
Post by el_ringo » Sun May 15, 2011 9:53 pm
Some more info on the trim and MAFs most likely.
http://www.ross-tech.com/vag-com/cars/fuel-trim.html
R
Daytona Grey (C5) RS6 saloon, but just a little better...
**** SOLD!!! :( ****
KW V3 suspension
390mm C6 Brakes
Hotchkis ARBs
Viper Tuning (537bhp 604lbft)
Unit 20 TCU remap
Milltek non-res exhaust and downpipes
100 cell sport cats
Aero wipers
Winter wheels
Wagner intercoolers
LED interior lights
Tesla Model S 85D
All the options with the exception of stupid air suspension
Tesla Model X 60D
Silly doors and all!
GaryCollinson
Post by GaryCollinson » Mon Sep 05, 2011 8:16 am
Just to close this particular post... It did appear to be down to the MAF sensors. Since these have been replaced the light has gone off and car has been running well (until recent fuel pump issue - but thats another post :-()
Thanks for all the help and suggestions.
Gary
Users browsing this forum: Majestic-12 [Bot] and 100 guests
