dittoSteve_C wrote:When my reading was just abvove MIN on the dipstick, I had no oil light on the dash. Does anyone know when the oil light should come on in theory?
I might have overfilled the oil
Re: I might have overfilled the oil
"you can be my wingman anytime!"
"bullshit...you can be mine!"
CheeRS
CheeRS
- Ice_Coffee
Afaik, for most cars it is when you are 1 litre down, this allows you to conveniently purchase a 1 litre bottle at he garage and top up
can someone advise as to the correct procedure to check the oil level? I inserted the dipstick right back in to the very end, when it kinda "gets stuck"...
is that how I am supposed to do this?
also: any fellow member in London I could borrow the vacuum pump from this weekend? would be very much obliged
CheeRS
CheeRS
As said before get a syringe and a length of tube from halfrauds and suck it out with that.
Current: RS4 B7 Saloon
Previous: BMW E46 330cd - Remapped to 250bhp and BBS LM's
VW Golf MKIV GT TDI 150BHP
Peugeot 206 GTi 180
Peugeot 206 GTi
Peugeot 206 1.1
Peugeot 206 GTi 180
Peugeot 206 GTi
Peugeot 206 1.1
Arthur had a thread recently about reading the dipstick, it was quite in-depth...
thanks - someone suggested a 50ml syringe
what's the best way for doing this? also the tube needs to be put where the dipstick is or where you normally put the oil in?
CheeRS
CheeRS
- PetrolDave
Yellow or red?Steve_C wrote:When my reading was just abvove MIN on the dipstick, I had no oil light on the dash. Does anyone know when the oil light should come on in theory?
Yellow comes on when the oil is about 0.5 litre below the min.
Red comes on when oil pressure is dangerously low - and your engine is shortly going to go expensively bang!
Dave what do you suggest to remove the oil overfill? I will go later to a DIY Shop and wanted to avoid driving my car with too much oil on it
CheeRS
CheeRS
Fudge knows why mine came on half way between max and min then. Whilst I check the dipstick manually from time to time, I'd much rather it was over keen than the opposite way around.
- PetrolDave
I'm with the answers you've already had above...pisquano wrote:Dave what do you suggest to remove the oil overfill?
ok but at what temperature should I check? 70 degrees? 100? results seem to vary according to this (and obviously so I should say)
it's just that now I don't remember what temp I had when I first noticed the oil seemed a bit low...
I found this thread that explains how "not clear" this is to some
http://forum.rs246.com/viewtopic.php?f= ... l+overfill
CheeRS
CheeRS
ours is the one on the right
if at or below C add 1 liter
if between C and B add 1/2 and check/adjust
if at B add <1/4 and check/adjust (but this is fine as is)
>B you are fine
>A over filled
check with oil hot >90 C
level ground (I always check in the same spot, garage, etc. for consistency)
do it within 3-5 minutes of shutdown
do it 2 or 3 times to get a repeatable reading
have a rag/paper towel to wipe the stick clean before reading
make sure stick is fully inserted, and withdraw slowly holding straight up
>B you are fine
>A over filled
- Attachments
- dipstick1.jpg (8.85 KiB) Viewed 1498 times
I could bastardize my penis pump for for you, will that do?pisquano wrote: also: any fellow member in London I could borrow the vacuum pump from this weekend? would be very much obliged
Thanks Arthur
1st reading was at C. Added 0.5 lt and now it reads above A
Clearly one of the readings was heavily wrong
Sonny: thanks for the offer but I'll decline
CheeRS
CheeRS
- Steve_C
- Top Gear
Pisquano - were both your readings at the same temp, same bit of level ground?
Whilst I know you shouldn't go above MAX, is there an amount you can go over MAX before having to suck some back out? 1/4 litre? I was talking to some guys today who do lots of track days etc (not in RS4s admittedly) and they all said they overfill the oil at the start of the day.
Gone to the dark side
