Dectane
Re: Dectane
andre, the two you have selected are exactly like the BM-Town ones and have bilbs rather than LEDs for the fog, reverse and indicator lights.
I think the Li-Tec ones are OK and may opt for the RA12SLRCL instead and the indicator LED block resembles the OEM B7 cluster rather than being an l-shape.
Re: Dectane
Nothing to do with the DRL's is it?Dannyrs4 wrote:I've got an issue with my lighting the now ever since I've fitted the LEDs which look superb btw. when I'm driving and I have my light switch set to off I have front sidelights on but the rears are off, any idea's?
Or am I being a bit obvious.
Re: Dectane
Has anybody tired these for the DRL's from Dectane!
They state they 21W tested, which has always been the problem with past LED's for the DRL's even with the Canbus!
https://www.dectane.de/product_info.php ... 57d824327a
Re: Dectane
I think the Dectane ones are a little different. The line of LEDs nearest the fogs seems much less angular with a bit of a curve to them which means there aren't as many LEDs in that bank (6 Dectane vs. 8 BM Town). Also, they have two versions of these on their website, the more expensive of which (€269) are all LED as far as I can work out save for the reverse lights:P_G wrote:andre, the two you have selected are exactly like the BM-Town ones and have bilbs rather than LEDs for the fog, reverse and indicator lights.
.LED Position light
.LED Brake light
.LED Indicator
.LED Fog light
.Rear light
.reflector included
.compatible with board computer
.E Mark
.bulb and wire included
.set includes 4 pieces
- PetrolDave
Re: Dectane
Check the DRL coding - there are 2 options - front only, or front & rear.Dannyrs4 wrote:I've got an issue with my lighting the now ever since I've fitted the LEDs which look superb btw. when I'm driving and I have my light switch set to off I have front sidelights on but the rears are off, any idea's?
Re: Dectane
My drl's are off though? As in the little switch is at zero so I assume they should be turned off?
- PetrolDave
Re: Dectane
So why are the front lights on at all?Dannyrs4 wrote:My drl's are off though? As in the little switch is at zero so I assume they should be turned off?
Still worth checking the coding IMHO.
Re: Dectane
That's what I don't understand light switch is at off and drl switch is at off.but front sidelights stay on all the time but rears are off it's a real pita
Re: Dectane
Hi
I'd like to get some rear lights for my silver saloon. Could someone tell me which ones are as close to what Audi are rolling out at the moment?
Also, where could I get them fitted or are they easy to do yourself?
G70
G70
Re: Dectane
Dave could you pm me how to check the coding because this issue is annoying me. I'll post pictures of the lights on my car they look great
- PetrolDave
Re: Dectane
See here http://wiki.ross-tech.com/wiki/index.ph ... 8EC/8ED%29Dannyrs4 wrote:Dave could you pm me how to check the coding because this issue is annoying me.
Re: Dectane
Now I'm not stating that this is the problem.... but certainly with domestic LED lamps (the 240v GU10 type for example): You can sometimes have a glow from the lamp even with the positive feed disconnected.Dannyrs4 wrote:That's what I don't understand light switch is at off and drl switch is at off.but front sidelights stay on all the time but rears are off it's a real pita
This is due to live induction into the neutral return.
Not sure if this is ever an issue with automotive 12V electrics and l.e.d.s
Just a thought.
Re: Dectane
It doesn't look like a glow tim it's as if my sidelights are actually on all day and my drl switch is off
Re: Dectane
Sounds like an incompatibility between the new lamps and the car then.... send 'em back.
Re: Dectane
Danny - is it your side-lights or your DRLs that are on all the time as trouble-shooting will depend upon which one is lit up ?Dannyrs4 wrote:That's what I don't understand light switch is at off and drl switch is at off.but front sidelights stay on all the time but rears are off it's a real pita
Users browsing this forum: Google Adsense [Bot] and 88 guests
