lugars4 wrote:Isnt that a gearbox off job ? Did u have clutch work done at the same time?wellzieRS4 wrote:Mine is spot on now, slides in smooth in any gear, it was the input shaft it needed greasing, it was sticking to the bearing. wot a difference sometimes i had to use a lot of force to select first gear now i can push it in with my finger
Yeah my gearbox was taken off to check the clutch and was done then, turned out to be clutch pipe did have support bracket and compressed but they still checked the clutch and it was fine
