as title, she has to go due to new circumstances.
anyone interested pm me
manual rs6 for sale
manual rs6 for sale
c6 rs6
Re: manual rs6 for sale
Manual 6 speed 01E Gearbox with hardened gearset
01E Gearbox Brackets
01E Gearbox Mounts
Pedal Box Conversion to manual
Clutch switch added
Clutch master cylinder/hydraulic lines/reservoir and slave cylinder added
Propshaft for manual box
Front driveshafts for manual box
Custom Flywheel
Custom Starter Motor
Custom adapter for gearbox
Custom Uprated ceramic Clutch kit
Gearbox linkage arms for manual box/manual gearstick box/trim for cabin
Custom Inconel Tubular manifolds – ceramic coated
2 off GT3071 Turbos with high flow compressors and back turbines/ internal wastegates
2 off wastegates
Custom brackets for wastegates
Custom oil lines for turbos
Custom water lines for turbos
Custom intake pipes for turbos
Custom Charge pipes
Custom 3” Race downpipes
Milltek catback exhaust
Twin air intake pipework/fcone filters and shrouds
Low compression headgasket set
Reconditioned/Ported heads
New tensioners and chains for heads
Full cambelt kit
Large Injector Kit
2 off Bosch Motorsport 10 bar fuel pump kits
Front Mounted Intercooler
Bumper modified to fit FMIC
2 off auxillary Side mounted water radiators
2 off auxillary side mounted oil coolers
Custom oil and water lines to coolers
Custom intercooler pipework
Bilstein PSS9 Suspension
H&R ARB Kit
C6 wheels
C6 front brakes
TTS Steering Wheel
Custom Engine/ABS Remap
All the gaskets/washers/bolts/nuts/clips/fasteners/silicon hoses etc.
Recaro sportster seats
Water / meth injection
01E Gearbox Mounts
Clutch switch added
Custom Flywheel
2 off wastegates
Custom Charge pipes
Full cambelt kit
Large Injector Kit
H&R ARB Kit
C6 wheels
C6 front brakes
TTS Steering Wheel
c6 rs6
